What is a default colour space (YcbCr, RGB?) and HDMI RGB range (full or limited) for Vero 4K /Vero 4K+
This was at the top of the list when using the forum search for “default color space”.
YCbCr; Limited Range.
Thank you
On my 1080p Sony TV model from 2008-ish I have an option Called “Colour space” in advanced picture settings and the options are standard and wide. Do you have a clue how to set it ?
I’m not going to try to answer that question, but I will suggest a different place to ask it.
If you’re in Britain or Europe, try www.avforums.com ; elsewhere in the world, especially in the US, try www.avsforum.com .
Loads of helpful and knowledgeable people on both sites.
