sometimes there is a different sound-delay on some files after upgrading to a new version.
This delay seems to be depedant on the resolution. There is no deley on 720p / 1080p / 4k files, but 576p / 480p files have a delay of about 200ms. I use sound-passthrough.
If I switch back to an older version of OSMC the delay is gone for all files.
(BTW: same issue on libreelec)
So I would like to have a possibility to set a audio-delay for a group of files (eg only 576p/480p).
FYI: Fileinfo
General Unique ID : 251713085511760064760901450214351717877
Complete name : /mnt/nas2/Media/Serien/S02E01.mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 672 MiB
Duration : 45 min 48 s
Overall bit rate : 2 051 kb/s
Movie name : Test
Encoded date : UTC 2017-05-02 20:52:12
Writing application : mkvmerge v9.8.0 (‘Kuglblids’) 64bit
Writing library : libebml v1.3.4 + libmatroska v1.4.5
Video
Format : AVC
Format profile : High@L4
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, RefFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Bit rate mode : Variable
Bit rate : 1 025 kb/s
Maximum bit rate : 40.0 Mb/s
Width : 708 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.126
Stream size : 336 MiB (50%)
Language : German
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.601 NTSC
Transfer characteristics : BT.709
Matrix coefficients : BT.601
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Format settings, Endianness : Big
Codec ID : A_AC3
Duration : 45 min 46 s
Bit rate mode : Constant
Bit rate : 640 kb/s
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 kHz
Bit depth : 16 bits
Compression mode : Lossy
Delay relative to video : 24 ms
Stream size : 210 MiB (31%)
Language : German
Service kind : Complete Main
Default : Yes
Forced : No
Audio #2
Format : AC-3
Codec ID : A_AC3
Duration : 45 min 47 s
Bit rate : 384 kb/s
Bit depth : 16 bits
Stream size : 126 MiB (19%)
Language : English
Default : No
Forced : No
