Hi all, wondering if I could please have a bit of advice on what is hopefully the final issue now that I have switched my OSMC server Pi from a 3 to a 4 and begun using NFS shares to hopefully improve 4K playback.
Admittedly this is not going to be a huge issue if it can’t be resolved but I’d like to try and understand what might be causing it.
From a fresh boot, the HDD connected directly to my Pi 4 OSMC server will take approx. 8 minutes to show up at it’s mount point (mnt/HDD). From other similar posts regarding NFS shares I’ve noted that it can sometimes be the “wait for network” option in My OSMC causing the delay, but I’ve tried with this enabled and disabled with no change.
My mount config is as follows
FSTAB
UUID=52D4C34DD4C331D1 /mnt/HDD ntfs defaults,noatime,nofail,x-systemd.mount-timeout=30 0 0
EXPORTS
/mnt/HDD 192.168.0.0/24(sync,no_subtree_check)
Many thanks for any assistance.
