Delay turning off TV when screen saver is activated
Hi - Hope you are well.
You can config osmc/kodi to put the tv into standby when the screen saver is activated. Is there a way to delay this command (for a specified period), so that the TV is not powered off straight away?
Essentially, Screen saver comes on, stays on for x minutes, then power/standby.
At the moment as soon as the screen saver is activated the tv is turned off, so you do not see the screen saver at all.
The only way I could think to reliably do this would be to use a custom screensaver add-on that lets you run Python commands.
