Hi guys
I wish to delete an addon-data folder but I get permission denied…error code 3 and request code 15
Using WinSCP - also tried filezilla to delete but failed
I tried from File manager in osmc but failed also.
The problem folder is .acestream from program.plexus
it was the previous user’s [hestiny] post which did not work…
sudo systemctl stop mediacenter works - it did stop kodi but still wasn’t able to delete folder
/home/osmc/.kodi/userdata/addon_data/program.plexus
should mention that I have the PI setup with sd card and usb
can’t access usb when I plugged it to my pc
…there’s an ACEstream folder inside program.plexus that does not get deleted
