I have the Denon x2300w and I had a similar issues but under Kodi and audio I can’t use the “AML-MSAUDIO,HDMI” I have to choose analog.
If choose the hdmi one, I get no audio but loud subwoofer noises.
No issues with the previous HTPC I had. Very odd.
There is no analog option. Do you mean PCM?
Is this only happening with DTS?
Please post debug logs so we can get a better handle on the issue.
Yes the aml-m8audio analog, PCM
@Temujin69 Hi, I split your post from the original thread since other AVR and new issue.
So, in summary:
- activate the logging
- reboot the OSMC device
- reproduce the issue
- upload the log set either using the
Log Uploadermethod within the My OSMC menu in the GUI or thesshmethod invoking commandgrab-logs -A - publish the provided URL from the log set upload, here
Thanks for your understanding. We hope that we can help you shortly.
