I’m trying to build the osmc vero3 source code.
I built and install the armv7 toolchain but I receive the following errors when I build the “mediacenter-osmc”:
Setting up openjdk-8-jre-headless:armhf (8u181-b13-2~deb9u1) ...
update-alternatives: using /usr/lib/jvm/java-8-openjdk-armhf/jre/bin/rmid to provide /usr/bin/rmid (rmid) in auto mode
update-alternatives: using /usr/lib/jvm/java-8-openjdk-armhf/jre/bin/java to provide /usr/bin/java (java) in auto mode
update-alternatives: using /usr/lib/jvm/java-8-openjdk-armhf/jre/bin/keytool to provide /usr/bin/keytool (keytool) in auto mode
update-alternatives: using /usr/lib/jvm/java-8-openjdk-armhf/jre/bin/jjs to provide /usr/bin/jjs (jjs) in auto mode
update-alternatives: using /usr/lib/jvm/java-8-openjdk-armhf/jre/bin/pack200 to provide /usr/bin/pack200 (pack200) in auto mode
update-alternatives: using /usr/lib/jvm/java-8-openjdk-armhf/jre/bin/rmiregistry to provide /usr/bin/rmiregistry (rmiregistry) in auto mode
update-alternatives: using /usr/lib/jvm/java-8-openjdk-armhf/jre/bin/unpack200 to provide /usr/bin/unpack200 (unpack200) in auto mode
update-alternatives: using /usr/lib/jvm/java-8-openjdk-armhf/jre/bin/orbd to provide /usr/bin/orbd (orbd) in auto mode
update-alternatives: using /usr/lib/jvm/java-8-openjdk-armhf/jre/bin/servertool to provide /usr/bin/servertool (servertool) in auto mode
update-alternatives: using /usr/lib/jvm/java-8-openjdk-armhf/jre/bin/tnameserv to provide /usr/bin/tnameserv (tnameserv) in auto mode
update-alternatives: using /usr/lib/jvm/java-8-openjdk-armhf/jre/lib/jexec to provide /usr/bin/jexec (jexec) in auto mode
Setting up ca-certificates-java (20170531+nmu1) ...
Adding debian:OpenTrust_Root_CA_G1.pem
Adding debian:Entrust_Root_Certification_Authority_-_G2.pem
Adding debian:D-TRUST_Root_Class_3_CA_2_EV_2009.pem
# A fatal error has been detected by the Java Runtime Environment:
# SIGSEGV (0xb) at pc=0xfdf78ff0, pid=17870, tid=0xf6756470
# JRE version: OpenJDK Runtime Environment (8.0_181-b13) (build 1.8.0_181-8u181-b13-2~deb9u1-b13)
# Java VM: OpenJDK Client VM (25.181-b13 mixed mode linux-aarch32 )
# Problematic frame:
# V [libjvm.so+0x2fbff0]
# Failed to write core dump. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again
# An error report file with more information is saved as:
# //hs_err_pid17870.log
Adding debian:COMODO_Certification_Authority.pem
Compiled method (c1) 721 40 java.util.regex.Matcher::search (109 bytes)
total in heap [0xfb8ba8c8,0xfb8bac08] = 832
relocation [0xfb8ba994,0xfb8ba9bc] = 40
main code [0xfb8ba9c0,0xfb8bab00] = 320
stub code [0xfb8bab00,0xfb8bab50] = 80
metadata [0xfb8bab50,0xfb8bab58] = 8
scopes data [0xfb8bab58,0xfb8bab90] = 56
scopes pcs [0xfb8bab90,0xfb8babf0] = 96
dependencies [0xfb8babf0,0xfb8babf4] = 4
nul chk table [0xfb8babf4,0xfb8bac08] = 20
Compiled method (c1) 722 40 java.util.regex.Matcher::search (109 bytes)
Adding debian:QuoVadis_Root_CA_1_G3.pem
# If you would like to submit a bug report, please visit:
# http://bugreport.java.com/bugreport/crash.jsp
qemu: uncaught target signal 6 (Aborted) - core dumped
/var/lib/dpkg/info/ca-certificates-java.postinst: line 43: 17867 Done find /etc/ssl/certs -name \*.pem
17868 Broken pipe | while read filename; do
alias=$(basename $filename .pem | tr A-Z a-z | tr -cs a-z0-9 _); alias=${alias%*_}; if [ -n "$FIXOLD" ]; then
echo "-${alias}"; echo "-${alias}_pem";
fi; echo "+${filename}";
done
17870 Aborted | java -Xmx64m -jar $JAR -storepass "$storepass"
dpkg: error processing package ca-certificates-java (--configure):
subprocess installed post-installation script returned error exit status 134
Setting up default-jre-headless (2:1.8-58) ...
Processing triggers for libc-bin (2.24-11+deb9u3) ...
Processing triggers for ca-certificates (20161130+nmu1+deb9u1) ...
Updating certificates in /etc/ssl/certs...
0 added, 0 removed; done.
Running hooks in /etc/ca-certificates/update.d...
done.
done.
Failed to install
Makefile:20: recipe for target 'vero3' failed
make: *** [vero3] Error 1
make: Leaving directory '/mnt/package/mediacenter-osmc'
make: *** [vero3] Error 2
thanks for the reply.
This is the error when the mediaceter-osmc is built without the arm7 toolchain:
Updating sources
Sources updated successfully
Package armv7-toolchain-osmc is not found on the system, checking APT
Can't find the package in APT repo. It needs to be built first or you need to wait for upstream to add it
Updating sources
Found in APT and will install
Installing package armv7-toolchain-osmc...
Reading package lists... Done
Building dependency tree
0 upgraded, 1 newly installed, 0 to remove and 18 not upgraded.
Need to get 57.1 MB of archives.
After this operation, 225 MB of additional disk space will be used.
Get:1 http://ftp.fau.de/osmc/osmc/apt stretch/main armhf armv7-toolchain-osmc all 1.4.4 [57.1 MB]
etc...
I know that there is the possibility to clone and get the armv7 toolchain from the repository.
Anyway, I’d like to build everything on my own from the source code.
Here below the steps that I followed (I’m building the code on a Ubuntu machine):
Build the armv7 toolchain:
~/osmc/toolchains/armv7-toolchain-osmc$ make
sudo bash build.sh
sudo rm -f *.deb > /dev/null 2>&1
sudo rm -rf output > /dev/null 2>&1
sudo rm -rf opt > /dev/null 2>&1
Updating sources
Configuring uname
Cleaning up filesystem
Removing ARM QEMU binary
Building Debian package
dpkg-deb: building package 'armv7-toolchain-osmc' in 'armv7-toolchain-osmc.deb'.
Build successful
Install the toolchain:
~/osmc/toolchains/armv7-toolchain-osmc$ sudo dpkg -i armv7-toolchain-osmc.deb
Selecting previously unselected package armv7-toolchain-osmc.
(Reading database ... 248466 files and directories currently installed.)
Preparing to unpack armv7-toolchain-osmc.deb ...
Unpacking armv7-toolchain-osmc (1.4.4) ...
Setting up armv7-toolchain-osmc (1.4.4) ...
Copying QEMU binary
Check if the toolchain has been properly installed:
~/osmc/toolchains/armv7-toolchain-osmc$ dpkg -l | grep toolchain
ii armv7-toolchain-osmc 1.4.4 all OSMC toolchain for ARMv7
Build the mediacenter-osmc package:
~/osmc/package/mediacenter-osmc$ make vero3
sudo bash build.sh "vero3"
Cleaning old source
Detected tarball source
Adding debian:Verisign_Class_2_Public_Primary_Certification_Authority_-_G3.pem
Adding debian:DigiCert_Global_Root_G2.pem
Adding debian:S-TRUST_Universal_Root_CA.pem
Adding debian:OISTE_WISeKey_Global_Root_GA_CA.pem
Adding debian:SecureSign_RootCA11.pem
Adding debian:SwissSign_Gold_CA_-_G2.pem
Adding debian:EE_Certification_Centre_Root_CA.pem
Adding debian:Swisscom_Root_CA_2.pem
Adding debian:Autoridad_de_Certificacion_Firmaprofesional_CIF_A62634068.pem
Adding debian:TrustCor_RootCert_CA-2.pem
Adding debian:AddTrust_Low-Value_Services_Root.pem
Adding debian:AffirmTrust_Commercial.pem
Adding debian:Certum_Trusted_Network_CA_2.pem
Adding debian:DigiCert_Assured_ID_Root_G2.pem
Adding debian:Deutsche_Telekom_Root_CA_2.pem
Adding debian:SSL.com_EV_Root_Certification_Authority_RSA_R2.pem
Adding debian:Sonera_Class_2_Root_CA.pem
Adding debian:Hellenic_Academic_and_Research_Institutions_RootCA_2011.pem
# SIGSEGV (0xb) at pc=0xfdf78ff0, pid=25779, tid=0xf6756470
# //hs_err_pid25779.log
Compiled method (c1) 1098 68 java.lang.Character::digit (6 bytes)
total in heap [0xfb8ce308,0xfb8ce568] = 608
relocation [0xfb8ce3d4,0xfb8ce3fc] = 40
main code [0xfb8ce400,0xfb8ce480] = 128
stub code [0xfb8ce480,0xfb8ce4e4] = 100
metadata [0xfb8ce4e4,0xfb8ce4f4] = 16
scopes data [0xfb8ce4f4,0xfb8ce524] = 48
scopes pcs [0xfb8ce524,0xfb8ce564] = 64
dependencies [0xfb8ce564,0xfb8ce568] = 4
Compiled method (c1) 1099 68 java.lang.Character::digit (6 bytes)
/var/lib/dpkg/info/ca-certificates-java.postinst: line 43: 25776 Done find /etc/ssl/certs -name \*.pem
25777 Broken pipe | while read filename; do
done
25779 Aborted | java -Xmx64m -jar $JAR -storepass "$storepass"
done.
done.
Failed to install
:~/osmc/toolchains$ sudo chroot /opt/osmc-tc/armv7-toolchain-osmc/
:/# sudo env LC_ALL=C apt-get -f install
Unknown host QEMU_IFLA type: 47
Unknown host QEMU_IFLA type: 48
Unknown host QEMU_IFLA type: 43
Reading package lists… Done
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
E: Can not write log (Is /dev/pts mounted?) - posix_openpt (19: No such device)
Setting up ca-certificates-java (20170531+nmu1) …
the keytool command requires a mounted proc fs (/proc).
dpkg: error processing package ca-certificates-java (–configure):
Processing triggers for ca-certificates (20161130+nmu1+deb9u1) …
Updating certificates in /etc/ssl/certs…
Running hooks in /etc/ca-certificates/update.d…
E: /etc/ca-certificates/update.d/jks-keystore exited with code 1.
done.
Note, I set the env because of a warning returned by perl. However I don’t think that is the cause of the ca-certificates-java error.
