Hope you can help with a Kodi specific network issue, however, it only appears days after booting up.
In the latest case, the device last booted 5th May and network issue appeared on 15th May.
When the issue appears, I can connect to the box via SSH, can ping, traceroute and curl to local servers and remote servers at the command line however at the Kodi app level Kodi seems to times out when trying to connect to remote servers.
The video library is connected to a https drive. When scanning for new files it returns a timeout error after 30 secs.
2024-05-24 19:17:00.340 T:11310 debug <general>: Thread JobWorker start, auto delete: true
2024-05-24 19:17:00.396 T:5382 debug <general>: ------ Window Init (DialogExtendedProgressBar.xml) ------
2024-05-24 19:17:00.415 T:11310 info <general>: VideoInfoScanner: Starting scan ..
2024-05-24 19:17:00.416 T:11310 debug <general>: easy_acquire - Created session to https://<redacted>.execute-api.eu-west-1.amazonaws.com
2024-05-24 19:17:00.416 T:11310 debug <general>: Curl::Debug - TEXT: Added <redacted>.execute-api.eu-west-1.amazonaws.com:443:34.255.157.115 to DNS cache
2024-05-24 19:17:00.417 T:11310 debug <general>: Curl::Debug - TEXT: Hostname <redacted>.execute-api.eu-west-1.amazonaws.com was found in DNS cache
2024-05-24 19:17:00.417 T:11310 debug <general>: Curl::Debug - TEXT: Trying 34.255.157.115:443...
2024-05-24 19:17:00.491 T:11311 debug <general>: Thread JobWorker start, auto delete: true
2024-05-24 19:17:22.090 T:4714 debug <CSettingsManager>: requested setting (_updates) was not found.
2024-05-24 19:17:30.419 T:11310 debug <general>: Curl::Debug - TEXT: Connection timed out after 30002 milliseconds
2024-05-24 19:17:30.420 T:11310 debug <general>: Curl::Debug - TEXT: Closing connection 0
2024-05-24 19:17:30.420 T:11310 error <general>: CCurlFile::Stat - <https://<redacted>.execute-api.eu-west-1.amazonaws.com/<redacted>/> Failed: Timeout was reached(28)
2024-05-24 19:17:30.420 T:11310 warning <general>: Process directory 'https://<redacted>.execute-api.eu-west-1.amazonaws.com/<redacted>/' does not exist - skipping scan.
2024-05-24 19:17:30.448 T:11310 info <general>: VideoInfoScanner: Finished scan. Scanning for video info took 30039 ms
Testing the same URL on the command line works fine
If i try to play an episode, I noted when debug mode is on, the text in top left freezes for a while then it will eventually begin to play around 40 seconds later.
If i reboot, it will be all fine for a number of days before appearing again. I’ve rebooted tonight but when it happens again is there any recommendations to help diagnose the issue?
