2021-06-11 20:20:48.965 T:4068199616 NOTICE: -----------------------------------------------------------------------
2021-06-11 20:20:48.965 T:4068199616 NOTICE: Starting Kodi (18.9). Platform: Linux ARM (Thumb) 32-bit
2021-06-11 20:20:48.965 T:4068199616 NOTICE: Using Release Kodi x32 build (version for Vero)
2021-06-11 20:20:48.965 T:4068199616 NOTICE: Kodi compiled 2020-11-27 by GCC 8.3.0 for Linux ARM (Thumb) 32-bit version 4.19.152 (267160)
2021-06-11 20:20:48.965 T:4068199616 NOTICE: Running on Open Source Media Center 2020.11-1, kernel: Linux ARM 32-bit version 3.14.29-160-osmc
Note here: Kodi(18.9) And I checked in System Info, the same.
Tried running OSMC update: there was none.
How do I get Kodi v19?
TIA
ken
PS: logs can be uploaded if requested. But, please, only if necessary. I think the log snippet above says a lot.
But v18 still uses python2. Some of the addons I would like to use now require python3. Could I install that manually? Or will it break something else?
I don’t know if you saw this post:
With that test build version (logs were uploaded, see previous posts), I had bad audio sync problems with several videos. Didn’t know if you had seen this post.
