I have been using the Vero 4K for a few days and am happy with it so far. One thing I noticed is the difference between using MyOSMC Update feature and apt-get dist-upgrade under the underlying Linux system. Whereas there is no myOSMC update currently (after I did the initial 2017.06-1 update the first time), sudo apt-get dist-upgrade lists package updates for various libraries. Is it normal? What are the differences?
Thanks in advance for your answers.
