today I have received my new Vero 2.
Now I want to disable to auto mount feature for external drives so that I can set an static mount at fstab.
Know anyone how it is possible?
Set fstab to mount inside /mnt and you’ll be fine. No need to disable anything.
Yea thats works.
But so the device is mounted twice.
At /mnt and at /media/XXX
Is there any way to disable the mount at /media/ ?
Probably something like:
sudo systemctl disable udisks-glue
This is untested.
