Is it possible to have OSMC / Vero ignore chapter markers? Trying to play a series I have downloaded but the chapters don’t seem to play nice with the player. Video’s are cutting out several minutes early and I can’t figure out why… (it’s only on those files, I checked other files and it’s fine)
Any help would be appreciated.
OSMC and Vero are not the media player. Kodi is the media player!
Logs would help:
So, in summary:
- activate the logging
- reboot the OSMC device
- reproduce the issue
- upload the log set either using the
Log Uploadermethod within the My OSMC menu in the GUI or thesshmethod invoking commandgrab-logs -A - publish the provided URL from the log set upload, here
If I’m calculating things correctly, there is a problem with the file:
00:28:19.403 T:3609195264 INFO: ffmpeg[D71FF300]: Duration: 00:20:51.29, start: 0.000000, bitrate: 399 kb/s
00:28:19.403 T:3609195264 INFO: ffmpeg[D71FF300]: Chapter #0:0: start 0.000000, end 80.623000
00:28:19.403 T:3609195264 INFO: ffmpeg[D71FF300]: Metadata:
00:28:19.403 T:3609195264 INFO: ffmpeg[D71FF300]: title : Opening
00:28:19.403 T:3609195264 INFO: ffmpeg[D71FF300]: Chapter #0:1: start 0.000000, end 1251.333000
00:28:19.404 T:3609195264 INFO: ffmpeg[D71FF300]: title : Main
00:28:19.404 T:3609195264 INFO: ffmpeg[D71FF300]: Chapter #0:2: start 0.000000, end 70.863000
00:28:19.404 T:3609195264 INFO: ffmpeg[D71FF300]: Metadata:
00:28:19.404 T:3609195264 INFO: ffmpeg[D71FF300]: title : Ending
According to that, the video is 20m 51s long, however if you look at the chapters, they add up to 1401 seconds which is about 23 minutes. That seems to match with your comment about ‘cutting out several minutes early’.
Of course I could be wrong about how to calculate the chapters properly…
It was cutting out at 17:40 for reasons that elude me. The chapters were set up to skip the intro and ending, but I think the whole encore is just screwed up. The files don’t play right on my PC…
Either way it seems the encoder released a V2 and those files are playing alright.
So re-encoded versions of the file fixed the problem? If so please mark this as solved.
