the internal BT device of my Pi3 is not that powerfull as a external USB BT dongle.
I wan’t to make sure that it is disabled completely to save power. (Pi connected in the car)
Is it enaugh to switch the default BT controller to the USB BT dongle with bluetoothctl or is there another option to disable the internal BT device?
regards ben
The Forum has this fancy search function on the top right. I guess we have to make it big and flashy so that people will see it.
https://discourse.osmc.tv/search?q=rpi3%20bluetooth%20disable
Add dtoverlay=pi3-disable-bt to /boot/config.txt. You need to be on the latest OSMC version for this to work.
Then run
sudo systemctl disable brcm43xx.service
thank you @fzinken for the hint. I searched but haven’t found this thread. will try it and reply, but I think that will work!
You can disable bluetooth through a device tree overlay in config.txt. See:
dev Set device name to search compatible module
(string, required)
speed Set SPI clock frequency in Hz
(integer, optional, default 500000)
Info: Configures the AVAGO APDS9960 digital proximity, ambient light, RGB and
gesture sensor
Load: dtoverlay=apds9960,<param>=<val>
Params: gpiopin GPIO used for INT (default 4)
noints Disable the interrupt GPIO line.
Info: Configures the Orchard Audio ApplePi-DAC audio card
Load: dtoverlay=applepi-dac
Params: <None>
