All I’m trying to do is restrict one samba user to read-only on all shares, but to do that I’ve come to understand that I need to disable automatic shares and define all shares manually. The next problem in the chain then becomes: how do I disable automatic samba shares?
I’ve tried:
- Setting
browsable = noin[automount template]according to this post - Deleting all directives under
[automount template]according to this post, except I did it insmb-local.confinstead
After rebooting all shares still show up on networked devices.
smb.conf:
[global]
# If you require a fully custom smb.conf create smb-local.conf instead of editing smb.conf so your
# configuration will not be overwritten by samba upgrades. You can use smb.conf as a template by
# copying it to smb-local.conf then removing the config file line below in the new file. If you only
# need to add some additional shares see smb-shares.conf below for a simpler way to do this.
config file = /etc/samba/smb-local.conf
smb-local.conf:
[global]
# time machine-specifikt
# från http://wa.rwick.com/2018/04/08/minimal-ubuntu-time-machine-backup-service/
vfs objects = catia fruit streams_xattr
mdns name = mdns
# Time Machine
fruit:veto_appledouble = no
fruit:encoding = native
fruit:metadata = stream
# Security
server min protocol = SMB2
workgroup = WORKGROUP
security=user
follow symlinks = yes
wide links = no
unix extensions = no
lock directory = /var/cache/samba
load printers = no
printing = bsd
printcap name = /dev/null
disable spoolss = yes
log level = 1
map to guest = bad user
# usershare template share = automount template
# Automount template disabled to work around a samba bug causing crashes accessing external drives.
read raw = Yes
write raw = Yes
strict locking = no
min receivefile size = 16384
use sendfile = true
aio read size = 2048
aio write size = 2048
socket options = TCP_NODELAY IPTOS_LOWDELAY SO_RCVBUF=131072 SO_SNDBUF=131072
[osmc]
browsable = yes
read only = no
valid users = osmc
path = /home/osmc
comment = OSMC Home Directory
# Från: https://discourse.osmc.tv/t/samba-automount-template-not-working/6038/6
# What you can do though is if it suits your needs better, is disable the automount shares by changing browseable = yes in the [automount template] section to no, then add a custom smb-shares.conf file that manually adds your desired shares with any permissions you like.
# Add custom shares in smb-shares.conf instead of editing smb.conf so they will not be
# overwritten by samba updates. You can only add new shares to smb-shares.conf, not change
# the default shares or global options. If you need full control see smb-local.conf above.
include = /etc/samba/smb-shares.conf
