Is it possible to disable the scrollbar on the OSMC skin? Personally I just don’t find it usual, and sometimes gets in the way.
Thanks,
Mark
Thanks,
Mark
You can via the skin settings, “Advanced” section
Ah thanks, I missed that.
Thanks for all your work on the skin by the way.
Mark
