I have got a soundbar that I have automatically configured to switch between inputs based on whether audio is coming from that input. Unfortunately my Vero4K+ is interfering with this by causing the input to switch when tvheadend recording notification occurs to indicate that a recording has started or stopped.
I think I found a workaround by disabling all Kodi GUI sounds… But I do like the audio feedback when navigating. Is there a way to disable this notification sound, but keep the GUI feedback sounds active?
I don’t think this is possible unfortunately
OK thanks Sam, appreciate the response
@wolf7250 An alternative approach to removing all GUI sounds would be removing all TVHeadend notifications.
Setting -> PVR & Live TV -> Recording -> Display a notification on timer updates.
Seems a lesser evil and only discovered the setting myself a few weeks ago.
“Recording started” - who cares? You might want to know if a scheduled recording didn’t start, but then it’s either too late to do anything about it or will be re-attempted automatically. And what are the chances you’re sitting there at the moment it pops up?
Get rid of the notifications. Keep your GUI sounds. You win.
Thanks @hissingshark!
I’m definitely giving this a go when I get home
