Hi 8go Sd Card is full, and i would like to not have to do a reinstall and delete stuff.
This is currently my system
df -h
Filesystem Size Used Avail Use% Mounted on
devtmpfs 362M 0 362M 0% /dev
tmpfs 367M 38M 330M 11% /run
/dev/mmcblk0p2 7.0G 6.5G 98M 99% /
tmpfs 367M 0 367M 0% /dev/shm
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 367M 0 367M 0% /sys/fs/cgroup
/dev/mmcblk0p1 240M 21M 219M 9% /boot
/dev/sda1 917G 368G 503G 43% /media/b8aec17f-a626-4780-89db-df9809bccb5e
tmpfs 74M 0 74M 0% /run/user/1000
runing du -hs on my home folder this is what i get
du -hs
725 Mo
I am complilling tvheadend so i have a folder with 1.2Go but the rest is certainly due to some packages i installed when trying retropie. How do i get rid of some of the excess stuff that i do not want…
