I am used to using the Confluence skin with Kodi and can configure that to show Movies in a Grid instead of the strip like configuration on the default OSMC skin.
Is it possible to configure the OSMC skin like this, or do i just need to use another skin like confluence?
We don’t have multiple views for the skin at the moment but I believe there may be plans to add more later.
That’s one for @BobCratchett to answer
Ok, thanks for the response.
Press Up or Left (depending on what view you’re currently in) to display the view options in the slide-out left hand menu. Then select the first option in the list to cycle through the views available - the closest we have is the ‘Wall’ view. Note that this view will only be available dependant on viewing library content, or a plugin having correctly set the media type.
Thank you, that is perfect
