My TV broke and I need to get it repaired or getting new… so, my father lent me some very old Panasonic plasma. Set-top box from tv provider works fine, but vero 4k+ just wont.
Thank you for suggestion.
I have plugged Vero to another, newer, TV set and worked great.
Funny thingy is that now, when I have tried then numerous time (many power cycles too), just works again. Actually the only thing different was following your suggestion and conect it to another TV set for a minute.
You mean the Vero is working on the Plasma now? Kinda looked to me like the TV was knackered and I wasn’t seeing anything wrong with the settings on the Vero. These TV’s can die in fits and starts. If it is working now it may not stay that way for too long and it is a very old TV at this point.
And I actually meant to plug a device other than the Vero into the plasma, not the other way round
Ok, so as I thought, Vero is sending RGB instead of YUV colour. I don’t know why, unless you have set that up in rc.local or something. Also it’s sending 10-bit colour when the TV only supports 8-bit. i don’t know why that is either - it should fall back to 8 bit.
If you are comfortable with the commandline, try typing this:
echo 8bitnow | sudo tee /sys/class/amhhdmitx/amhdmitx0/attr
If that works, then add a line to /etc/rc.local by typing
