Display Rotation 180 no longer works
Hello folks,
my starting situation is a Picture Frame with a up side down intallated Screen (not possible otherwise)
For Years it works fine with the Opthion in MyOSMC Settings to Rotate 180, after a Update doesn’t do it anymore. (Without touching the Settings.
If have tried to turn the Option off and on again. - Failed
I have waited 1 or 2 Updates, but i never was fixed.
I have tried to wirite the Config with a Rotation Code (only one at a Time):
display_hdmi_rotate=2
display_lcd_rotate=2
lcd_rotate=2
video=DPI-1,1920x1080M@60,rotate=180
All Failed.
After this, i have wiped the ssd and reinstalld the newest version of OSMC, but i doesnt work.
It seem, that the Option MyOSMC Settings to rotate the Display is broken.
Or is there a other Idea?
Thx all and a happy new Year
Which version of OSMC did you update from?
There is a new video stack for Raspberry Pi, and it’s possible this functionality is no longer supported if you updated from a version before Kodi v19.
