Hello to everybody.
I’m running OSMC with Kodi 19.1 (VERSION_ID=“2021.08-1”) on a Raspberry 3B.
I’m having a bounch of “Division by zero in kernel” messages during the boot.
After that everything seems to function proprerly.
Can anybody help to understand those messages and what I have to do to remove them?
Here are a couple of them:
[ 20.503657] Division by zero in kernel.
[ 20.503681] CPU: 2 PID: 414 Comm: kodi.bin Tainted: G C 5.10.32-2-osmc #1
[ 20.503685] Hardware name: BCM2835
[ 20.503690] Backtrace:
[ 20.503712] [<80b6d238>] (dump_backtrace) from [<80b6d5c4>] (show_stack+0x20/0x24)
[ 20.503721] r7:812e5f50 r6:00000000 r5:60070013 r4:812e5f50
[ 20.503731] [<80b6d5a4>] (show_stack) from [<80b71fac>] (dump_stack+0xbc/0xe8)
[ 20.503739] [<80b71ef0>] (dump_stack) from [<80b6d3b8>] (__div0+0x24/0x28)
[ 20.503747] r9:00000000 r8:0000000f r7:00000001 r6:812e8210 r5:00000008 r4:00000000
[ 20.503756] [<80b6d394>] (__div0) from [<807427d0>] (Ldiv0_64+0x8/0x18)
[ 20.503767] [<807badd4>] (bcm2835_clock_choose_div) from [<807bb2d8>] (bcm2835_clock_determine_rate+0x2a0/0x324)
[ 20.503776] r9:00000000 r8:00000014 r7:00000001 r6:00000000 r5:812e8210 r4:0124f800
[ 20.503786] [<807bb038>] (bcm2835_clock_determine_rate) from [<807acd80>] (clk_core_round_rate_nolock+0x6c/0x108)
[ 20.503795] r10:80e77df0 r9:00000001 r8:00000014 r7:00000000 r6:00000000 r5:84049b98
[ 20.503799] r4:82494d80
[ 20.503810] [<807acd14>] (clk_core_round_rate_nolock) from [<807b31cc>] (clk_core_set_rate_nolock+0x120/0x440)
[ 20.503817] r7:00000000 r6:00000000 r5:81205008 r4:82494d80
[ 20.503826] [<807b30ac>] (clk_core_set_rate_nolock) from [<807b3a34>] (clk_request_done+0xa4/0xb0)
[ 20.503835] r10:80e77df0 r9:00000001 r8:00000014 r7:842aa284 r6:842ad040 r5:82494d80
[ 20.503839] r4:84056000
[ 20.503909] [<807b3990>] (clk_request_done) from [<7f61cb90>] (vc4_hdmi_encoder_post_crtc_powerdown+0x198/0x248 [vc4])
[ 20.503915] r5:84361880 r4:842aa284
[ 20.504014] [<7f61c9f8>] (vc4_hdmi_encoder_post_crtc_powerdown [vc4]) from [<7f60d468>] (vc4_crtc_disable+0x174/0x1b8 [vc4])
[ 20.504019] r5:0ccccb60 r4:00000000
[ 20.504119] [<7f60d2f4>] (vc4_crtc_disable [vc4]) from [<7f60e034>] (vc4_crtc_atomic_disable+0x60/0xe0 [vc4])
[ 20.504128] r10:7f5f20cd r9:7f6350b0 r8:7f5f005c r7:84133200 r6:843dbc40 r5:842aa800
[ 20.504133] r4:842ad040
[ 20.504271] [<7f60dfd4>] (vc4_crtc_atomic_disable [vc4]) from [<7f5dd490>] (drm_atomic_helper_commit_modeset_disables+0x37c/0x76c [drm_kms_helper])
[ 20.504279] r7:84164c00 r6:00000003 r5:842ad040 r4:843dbc40
[ 20.504396] [<7f5dd114>] (drm_atomic_helper_commit_modeset_disables [drm_kms_helper]) from [<7f6163f8>] (vc4_atomic_complete_commit+0xbc/0x680 [vc4])
[ 20.504405] r10:84049e34 r9:00000000 r8:842aace8 r7:84171440 r6:842aa800 r5:843dbc40
[ 20.504409] r4:00000004
[ 20.504507] [<7f61633c>] (vc4_atomic_complete_commit [vc4]) from [<7f616b40>] (vc4_atomic_commit+0x184/0x1d4 [vc4])
[ 20.504516] r10:84049e34 r9:00000000 r8:842aace8 r7:00000000 r6:00000000 r5:842aa800
[ 20.504521] r4:843dbc40 r3:00000001
[ 20.504759] [<7f6169bc>] (vc4_atomic_commit [vc4]) from [<7f52a150>] (drm_atomic_commit+0x54/0x60 [drm])
[ 20.504769] r9:843dbc40 r8:ffffe000 r7:00000000 r6:842aa800 r5:843dbc40 r4:00000000
[ 20.505052] [<7f52a0fc>] (drm_atomic_commit [drm]) from [<7f548ddc>] (drm_mode_atomic_ioctl+0x95c/0xab4 [drm])
[ 20.505059] r7:00000000 r6:00000003 r5:00000000 r4:00000000
[ 20.505329] [<7f548480>] (drm_mode_atomic_ioctl [drm]) from [<7f50fb1c>] (drm_ioctl_kernel+0xb8/0xfc [drm])
[ 20.505338] r10:84049e34 r9:7f548480 r8:00000002 r7:00000000 r6:83d1e800 r5:842aa800
[ 20.505342] r4:81205008
[ 20.505611] [<7f50fa64>] (drm_ioctl_kernel [drm]) from [<7f50fd5c>] (drm_ioctl+0x1fc/0x3c4 [drm])
[ 20.505620] r10:84049e34 r9:84049e34 r8:83d1e800 r7:000000bc r6:81205008 r5:7f552c2c
[ 20.505625] r4:00000038
[ 20.505769] [<7f50fb60>] (drm_ioctl [drm]) from [<803bb288>] (sys_ioctl+0x1dc/0xa98)
[ 20.505779] r10:00000000 r9:84048000 r8:7ec9a910 r7:8328ed80 r6:8328ed81 r5:81205008
[ 20.505784] r4:c03864bc
[ 20.505795] [<803bb0ac>] (sys_ioctl) from [<80100040>] (ret_fast_syscall+0x0/0x28)
[ 20.505801] Exception stack(0x84049fa8 to 0x84049ff0)
[ 20.505809] 9fa0: 073f4c00 7ec9a910 00000000 c03864bc 7ec9a910 00000000
[ 20.505817] 9fc0: 073f4c00 7ec9a910 c03864bc 00000036 07399958 073fb8f0 00000000 00000000
[ 20.505823] 9fe0: 7610608c 7ec9a8dc 760efe9b 75935f08
[ 20.505832] r10:00000036 r9:84048000 r8:80100204 r7:00000036 r6:c03864bc r5:7ec9a910
[ 20.505837] r4:073f4c00
[ 20.505877] Division by zero in kernel.
[ 20.505889] CPU: 2 PID: 414 Comm: kodi.bin Tainted: G C 5.10.32-2-osmc #1
[ 20.505894] Hardware name: BCM2835
[ 20.505898] Backtrace:
[ 20.505914] [<80b6d238>] (dump_backtrace) from [<80b6d5c4>] (show_stack+0x20/0x24)
[ 20.505922] r7:812e5f50 r6:00000000 r5:60070013 r4:812e5f50
[ 20.505931] [<80b6d5a4>] (show_stack) from [<80b71fac>] (dump_stack+0xbc/0xe8)
[ 20.505939] [<80b71ef0>] (dump_stack) from [<80b6d3b8>] (__div0+0x24/0x28)
[ 20.505948] r9:00000000 r8:0000000f r7:00000001 r6:812e8210 r5:00000008 r4:00000000
[ 20.505957] [<80b6d394>] (__div0) from [<807427d0>] (Ldiv0_64+0x8/0x18)
[ 20.505967] [<807badd4>] (bcm2835_clock_choose_div) from [<807bb2d8>] (bcm2835_clock_determine_rate+0x2a0/0x324)
[ 20.505976] r9:00000000 r8:00001000 r7:00000006 r6:00000000 r5:812e8210 r4:1dcd6506
[ 20.505986] [<807bb038>] (bcm2835_clock_determine_rate) from [<807acd80>] (clk_core_round_rate_nolock+0x6c/0x108)
[ 20.505995] r10:80e77df0 r9:00000001 r8:00000014 r7:00000000 r6:00000000 r5:84049b98
[ 20.506000] r4:82494d80
[ 20.506010] [<807acd14>] (clk_core_round_rate_nolock) from [<807b31cc>] (clk_core_set_rate_nolock+0x120/0x440)
[ 20.506017] r7:00000000 r6:00000000 r5:81205008 r4:82494d80
[ 20.506026] [<807b30ac>] (clk_core_set_rate_nolock) from [<807b3a34>] (clk_request_done+0xa4/0xb0)
[ 20.506035] r10:80e77df0 r9:00000001 r8:00000014 r7:842aa284 r6:842ad040 r5:82494d80
[ 20.506039] r4:84056000
[ 20.506103] [<807b3990>] (clk_request_done) from [<7f61cb90>] (vc4_hdmi_encoder_post_crtc_powerdown+0x198/0x248 [vc4])
[ 20.506109] r5:84361880 r4:842aa284
[ 20.506208] [<7f61c9f8>] (vc4_hdmi_encoder_post_crtc_powerdown [vc4]) from [<7f60d468>] (vc4_crtc_disable+0x174/0x1b8 [vc4])
[ 20.506214] r5:0ccccb60 r4:00000000
[ 20.506313] [<7f60d2f4>] (vc4_crtc_disable [vc4]) from [<7f60e034>] (vc4_crtc_atomic_disable+0x60/0xe0 [vc4])
[ 20.506322] r10:7f5f20cd r9:7f6350b0 r8:7f5f005c r7:84133200 r6:843dbc40 r5:842aa800
[ 20.506327] r4:842ad040
[ 20.506473] [<7f60dfd4>] (vc4_crtc_atomic_disable [vc4]) from [<7f5dd490>] (drm_atomic_helper_commit_modeset_disables+0x37c/0x76c [drm_kms_helper])
[ 20.506480] r7:84164c00 r6:00000003 r5:842ad040 r4:843dbc40
[ 20.506600] [<7f5dd114>] (drm_atomic_helper_commit_modeset_disables [drm_kms_helper]) from [<7f6163f8>] (vc4_atomic_complete_commit+0xbc/0x680 [vc4])
[ 20.506609] r10:84049e34 r9:00000000 r8:842aace8 r7:84171440 r6:842aa800 r5:843dbc40
[ 20.506613] r4:00000004
[ 20.506712] [<7f61633c>] (vc4_atomic_complete_commit [vc4]) from [<7f616b40>] (vc4_atomic_commit+0x184/0x1d4 [vc4])
[ 20.506721] r10:84049e34 r9:00000000 r8:842aace8 r7:00000000 r6:00000000 r5:842aa800
[ 20.506726] r4:843dbc40 r3:00000001
[ 20.506953] [<7f6169bc>] (vc4_atomic_commit [vc4]) from [<7f52a150>] (drm_atomic_commit+0x54/0x60 [drm])
[ 20.506962] r9:843dbc40 r8:ffffe000 r7:00000000 r6:842aa800 r5:843dbc40 r4:00000000
[ 20.507243] [<7f52a0fc>] (drm_atomic_commit [drm]) from [<7f548ddc>] (drm_mode_atomic_ioctl+0x95c/0xab4 [drm])
[ 20.507251] r7:00000000 r6:00000003 r5:00000000 r4:00000000
[ 20.507520] [<7f548480>] (drm_mode_atomic_ioctl [drm]) from [<7f50fb1c>] (drm_ioctl_kernel+0xb8/0xfc [drm])
[ 20.507529] r10:84049e34 r9:7f548480 r8:00000002 r7:00000000 r6:83d1e800 r5:842aa800
[ 20.507533] r4:81205008
[ 20.507802] [<7f50fa64>] (drm_ioctl_kernel [drm]) from [<7f50fd5c>] (drm_ioctl+0x1fc/0x3c4 [drm])
[ 20.507811] r10:84049e34 r9:84049e34 r8:83d1e800 r7:000000bc r6:81205008 r5:7f552c2c
[ 20.507816] r4:00000038
[ 20.507960] [<7f50fb60>] (drm_ioctl [drm]) from [<803bb288>] (sys_ioctl+0x1dc/0xa98)
[ 20.507969] r10:00000000 r9:84048000 r8:7ec9a910 r7:8328ed80 r6:8328ed81 r5:81205008
[ 20.507974] r4:c03864bc
[ 20.507984] [<803bb0ac>] (sys_ioctl) from [<80100040>] (ret_fast_syscall+0x0/0x28)
[ 20.507990] Exception stack(0x84049fa8 to 0x84049ff0)
[ 20.507998] 9fa0: 073f4c00 7ec9a910 00000000 c03864bc 7ec9a910 00000000
[ 20.508006] 9fc0: 073f4c00 7ec9a910 c03864bc 00000036 07399958 073fb8f0 00000000 00000000
[ 20.508012] 9fe0: 7610608c 7ec9a8dc 760efe9b 75935f08
[ 20.508021] r10:00000036 r9:84048000 r8:80100204 r7:00000036 r6:c03864bc r5:7ec9a910
[ 20.508025] r4:073f4c00
TIA
