This problems started last week when I tried to update my raspi 2 to the hotfix version, before that everything was working as it should.
When I tried to update from April version to that one, the raspi rebooted and entered the blue install screen but after a couple of hours it was still at that point so I rebooted.
Since then everything seemed ok except an error when I tried to update again, it just told me that it failed and that I should report the error here.
Also I noticed that transmission was no longer connecting to the tracker but to me that was a problem with the tracker.
I had some spare time today and tried to get a log uploaded to report the update problem but it fails with no url, then after looking a bit more it seems that dns client is not working anymore, pings return bad address, transmission not working, log upload not working, apt-get shows errors resolving addresses, etc.
I did disable and re enable the wired connection within My OSMC but without any luck, I have been trying to find solutions over the internet but I don’t have /etc/resolv.conf
osmc@osmc:~$ ifconfig -a
eth0 Link encap:Ethernet HWaddr b8:27:eb:91:0e:b1
inet addr:192.168.1.150 Bcast:192.168.1.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST DYNAMIC MTU:1500 Metric:1
RX packets:13393 errors:0 dropped:0 overruns:0 frame:0
TX packets:7686 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:4045188 (3.8 MiB) TX bytes:1759216 (1.6 MiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:67539 errors:0 dropped:0 overruns:0 frame:0
TX packets:67539 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:5800509 (5.5 MiB) TX bytes:5800509 (5.5 MiB)
I still have local connection but it seems there is some problem or missing component with dns.
