HI! I’m trying to run ownCloud on my Vero 4+ box using docker, however I get stuck on this issue: Cannot use 10.6 or 10.5 on arm, permission error during install process · Issue #219 · owncloud-docker/server · GitHub
After check the libseccomp2 version on my box it seems it’s indeed outdated:
osmc@osmc:~$ sudo dpkg -l libseccomp2
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
ii libseccomp2:armhf 2.3.3-4 armhf high level interface to Linux seccomp filter
There are solutions floating on the web, such as this one: Install Docker on Raspberry Pi | Unix etc.
…but I no idea if it’s a good idea to install unsupported version of the lib.
Are there any plans to update the lib? My system version is: 2022.03-1.
Thanks!
