I currently have an RPi Model B (first gen) which I use as a bedroom media centre with OSMC. I have recently been using HEVC videos as my standard which work fine on my PC but the RPi struggles to play them at 1fps! I have read through the forums and it sounds like the RPi 3 should be able to play them smoothly? Is this correct? If so I will order one asap. To be clear, I don’t need 4k playback. Most of my HEVC videos are 720p but some are 1080p .
Most 720p should be fine, for 1080p it really depends on several factors you might only get 50% playing fine.
Only OSMC device that plays all of them without issue is the Vero4k (evenso you don’t need 4k)
My pi3B will play 10 bit HEVC if I disable MMAL (hardware decoding). Some say if you buy a MPG2 codec license it will work with MMAL.
Pi4B plays them OK because there in no MMAL.
