Does CUPS work with OSMC
I finally bought a rpi and installed OSMC. I can see that others use rpi’s as Google Cloud Print servers but is it possible to do with OSMC?
Yes. If you can do it with Raspbian, you can do it with OSMC
wow quick answer thanks. I will look into that.
