hallo all
I installed kodi19 a few weeks ago, it was always relatively warm but I didn’t think about anything.
The Vero 4K + has not started since yesterday. I tried to reinstall it using a USB stick, but exactly the same thing happens, it remains in the picture please stand by.
hallo
normally this is not on the towel until now just made for the photo, I also have a replacement SD should I try it? I thought it could be done with a USB stick.
I installed that with the SD card, I think the installation went through wonderfully, but then the same situation it stops at picture please stand by.
here is the log from the installation.
Sun Jan 1 00:00:12 2017 Starting OSMC installer
Sun Jan 1 00:00:14 2017 Detecting device we are running on
Sun Jan 1 00:00:14 2017 Mounting boot filesystem
Sun Jan 1 00:00:14 2017 Trying to mount to MNT_BOOT (/mnt/boot)
Sun Jan 1 00:00:14 2017 Using device->boot: /dev/mmcblk1p1 and FS: fat32
Sun Jan 1 00:00:14 2017 Filesystem defined by /mnt/boot/filesystem.tar.xz
Sun Jan 1 00:00:14 2017 No preseed file was found
Sun Jan 1 00:00:14 2017 Flash looks OK
Sun Jan 1 00:01:18 2017 Creating root partition
Sun Jan 1 00:01:19 2017 Calling fmtpart for partition /dev/vero-nand/root and fstype ext4
Sun Jan 1 00:01:22 2017 Filesystem label=
OS type: Linux
Block size=4096 (log=2)
Fragment size=4096 (log=2)
Stride=2 blocks, Stripe width=1024 blocks
930240 inodes, 3716096 blocks
185804 blocks (5.00%) reserved for the super user
First data block=0
Maximum filesystem blocks=3808428032
114 block groups
32768 blocks per group, 32768 fragments per group
8160 inodes per group
Superblock backups stored on blocks:
32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208
Sun Jan 1 00:01:22 2017 From a root partition of /dev/vero-nand/root, I have deduced a base device of /dev/vero-nand/roo
Sun Jan 1 00:01:22 2017 Mounting root
Sun Jan 1 00:01:22 2017 Trying to mount to MNT_ROOT (/mnt/root)
Sun Jan 1 00:01:22 2017 Using device->root: /dev/vero-nand/root
Sun Jan 1 00:01:22 2017 Extracting files to root filesystem
Sun Jan 1 00:01:22 2017 Starting extract process …
Sun Jan 1 00:01:22 2017 Extracting from /mnt/boot/filesystem.tar.xz
Sun Jan 1 00:02:27 2017 Extraction of root filesystem completed
Sun Jan 1 00:02:27 2017 Configuring bootloader
Sun Jan 1 00:02:27 2017 Configuring bootloader: moving /boot to appropriate boot partition
Sun Jan 1 00:02:28 2017 Vero 4K family: bootloader to be flashed is uboot-vero4kplus.bin
Sun Jan 1 00:02:29 2017 Configuring boot cmdline
Sun Jan 1 00:02:29 2017 Configuring /etc/fstab
Sun Jan 1 00:02:29 2017 Successful installation. Dumping log and rebooting system
strange but I use the power supply that I got and it worked there for about a year.
So I tried again on a different socket and in a different room but the same situation, can I use another power supply to rest theirs and so what are the values that must have?
