Does "update library" not work on old devices anymore?
I have a few v4k and a v4k+, the update library thing doesnt seem to work anymore. Doesn’t return an error message.
… In actual fact, the TV shows one is working… a bit, i‘the movie database’ one that isn’t at all
Without logs, it’s going to be impossible to tell. You didn’t even tell us what OSMC build and Kodi version you have. Assuming you are as up to date as you can be, scraping should still work. Although it’s possible you were still using the very old XML based scrapers. Those have mostly stopped working. You’d need to switch to the Python ones. Again, these are all things a debug log file would help identify.
Movies and TV Shows both update on my old Vero 4K+ box.
Indeed. We need some more information to advise.
I have a similar issue. Logs: https://paste.osmc.tv/lehakicahu
Stagecoach is the latest one that isn’t getting added to the library.
Go to your TV Show source and change your scraper from the old TMDB one to the TMDB Python one.
Thank you, this worked.
