Hi everyone,
I’m considering purchasing a Vero V to use with my Samsung S95C TV and Q990C soundbar. My media library is managed through Jellyfin. I have a couple of specific requirements and wanted to double-check if the Vero V supports them.
- Does the Vero V, with the Jellyfin add-on for Kodi, support full Dolby Atmos with TrueHD passthrough, including the height channels?
- Is HDR10+ also supported in this setup?
Thanks in advance for your help!
Yes - shouldn’t be a problem, as long as Jellyfin isn’t doing anything like transcoding to a lower quality. You should be able to configure this.
HDR10+ is also supported.
Excellent, thank you, @sam_nazarko - I’ve just placed my order.
@lmt464 I have the same soundbar; Dolby TrueHD with Dolby Atmos works perfect.
Just make sure that the first thing you do is enable it in Settings > System > Audio, check “Allow passthrough” and then check every box below that e.g. TrueHD capable receiver, DTS-HD capable receiver etc.
