Dolby Atmos 5.1.2 audio support on OSMC Vero
Hello how can we enable or get Vero to play atmos 5.1.2 on my atmos speakers? Is there a workaround or an update for this to happen. Same for DTS-X and Auro 3D.
Vero does not support Atmos; just DTS TrueHD and DTS HD MA
Vero should not care. As it is done by ALSA it is just raw bitstream using the same packer as truehd uses while just “overreading” the atmos bits. So if truehd works - Atmos should also work - in passthrough mode.
