Hello, I have installed Transmission on my PI 3 from the OSMC app store.
It is version 2.84:
$transmission-daemon -v
Transmission 2.84 (14307) http://www.transmissionbt.com/
I would like to downgrade it to v. 2.82, that is the last supported by transmissionrpc, a python library needed by Flexget to control the transmission daemon.
Can I just do a
$sudo apt-get install transmission-daemon=2.82
or this is could cause issues with other dependencies?
Which is the best way to downgrade Transmission?
Thanks!
