I still would like the Android Build if possible. I have some spare time, so i could do some testing if you want me to.
And yes, this time i will be logging every thing.
My plan is 1. to reproduce the error as posted before, 2.to install June from scratch and 3. Install Android and see where the stuttering comes from.
So if this sounds good, let me know and ill post in a new thread my findings.
Currently if you install the Android release for NAND, you will likely not be able to trivially reinstall OSMC.
If you are just after Android to see if it addresses playback problems, it won’t. Just start a proper thread with logs first, and we’ll look in to it.
I used to compile hardened Gentoo kernels, so i dont think it will be a problem. But to save everyone the hassle, ill work around it. Ill just emulate Android on osmc as a service and test from there. If the emulated kodi functions without a hitch, the problem must be in the Kodi installed with osmc. I will still test every thing and of course will post if i find anything.
You seem to be over complicating things. You just need to produce one log and a clip that exhibits a problem, and we will address it
