Hi, my Vero4k lately doesn’t show subtitles it downloads. They appear in the subtitle list, but they don’t show up. External subtitles that I put in the directory myself from my PC work well.
Any suggestions?
Are you using the opensubtitles.org add-on and does it download a srt that only contains a single line? If so this would likely be the change they made switching between their .org and .com sites. They want you to pay money and use an api key to use their old services now. Try removing the .org add-on and install the newer one for the .com site.
Thank you very much! <3
