I am wondering what I need to compile the driver needed to use my usb wifi card. I have tried plugging up to the atv using a powered usb hub and it still doesn’t come on. I’m pretty sure I need to install the drivers for the card on the atv.
Well the first stage there is always to provide a dmesg output so that the ID of the device is clear and we can see if a potential driver exists.
But a quick google with the device name indicates that there is currently no kernel driver for this device.
Currently I am following a guide on trying to make the driver, but I run into problems when trying to run the make command. It seems that it can’t find the headers for osmc.
I checked to make sure that the headers where installed, and they where. It seems to be a problem with the makefile I believe. I was wondering what directory the headers are in? This should hopefully send me in the right direction.
