I have installed OSMC on a Raspberry Pi 2 and trying to enable WiFi.
I have a cheap wifi dongle with 8188eu chip and cannot scan for wifi networks.
lsusb returns this:
Bus 001 Device 005: ID 0bda:8179 Realtek Semiconductor Corp.
Bus 001 Device 004: ID 04fc:0538 Sunplus Technology Co., Ltd Wireless Optical Mouse 2.4G [Bright]
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
lsmod:
Module Size Used by 8021q 22147 0 garp 7622 1 8021q stp 2430 1 garp llc 6031 2 stp,garp bnep 12310 2 bluetooth 425632 5 bnep uinput 9818 1 r8188eu 538834 0 cfg80211 549675 1 r8188eu evdev 13192 2 joydev 9585 0 rfkill 22566 5 cfg80211,bluetooth snd_bcm2835 24682 0 snd_pcm 115646 1 snd_bcm2835 snd_timer 24969 1 snd_pcm snd 78090 3 snd_bcm2835,snd_timer,snd_pcm bcm2835_thermal 2844 0 bcm2835_gpiomem 4026 0 bcm2835_wdt 4081 0 uio_pdrv_genirq 3885 0 lirc_rpi 9315 3 lirc_dev 11576 1 lirc_rpi rc_core 25745 1 lirc_dev uio 10428 1 uio_pdrv_genirq fuse 106814 1 ipv6 447478 42
and dmesg:
[ 0.000000] Booting Linux on physical CPU 0xf00
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.0-1-osmc (root@vero) (gcc version 4.9.2 (Debian 4.9.2-10) ) #1 SMP PREEMPT Tue Jan 12 17:56:48 UTC 2016
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: Raspberry Pi 2 Model B Rev 1.1
[ 0.000000] cma: Reserved 8 MiB at 0x2e400000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 192512
[ 0.000000] free_area_init_node: node 0, pgdat 80bbd780, node_mem_map add64000
[ 0.000000] Normal zone: 1692 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 192512 pages, LIFO batch:31
[ 0.000000] [bcm2709_smp_init_cpus] enter (9660->f3003010)
[ 0.000000] [bcm2709_smp_init_cpus] ncores=4
[ 0.000000] PERCPU: Embedded 13 pages/cpu @aefac000 s23552 r8192 d21504 u53248
[ 0.000000] pcpu-alloc: s23552 r8192 d21504 u53248 alloc=13*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 190820
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2709.boardrev=0xa01041 bcm2709.serial=0x31c62ba9 smsc95xx.macaddr=B8:27:EB:C6:2B:A9 bcm2708_fb.fbswap=1 bcm2709.uart_clock=3000000 bcm2709.disk_led_gpio=47 bcm2709.disk_led_active_low=0 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait quiet osmcdev=rbp2
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 741152K/770048K available (7941K kernel code, 436K rwdata, 1860K rodata, 1788K init, 764K bss, 20704K reserved, 8192K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xaf800000 - 0xff800000 (1280 MB)
lowmem : 0x80000000 - 0xaf000000 ( 752 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x80008000 - 0x8099a69c (9802 kB)
.init : 0x8099b000 - 0x80b5a000 (1788 kB)
.data : 0x80b5a000 - 0x80bc7384 ( 437 kB)
.bss : 0x80bca000 - 0x80c8926c ( 765 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000011] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000033] Switching to timer-based delay loop, resolution 52ns
[ 0.000337] Console: colour dummy device 80x30
[ 0.000563] console [tty0] enabled
[ 0.000590] Calibrating delay loop (skipped), value calculated using timer frequency… 38.40 BogoMIPS (lpj=192000)
[ 0.000619] pid_max: default: 32768 minimum: 301
[ 0.000971] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000993] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.002221] Disabling cpuset control group subsystem
[ 0.002270] Initializing cgroup subsys io
[ 0.002302] Initializing cgroup subsys memory
[ 0.002358] Initializing cgroup subsys devices
[ 0.002384] Initializing cgroup subsys freezer
[ 0.002409] Initializing cgroup subsys net_cls
[ 0.002478] CPU: Testing write buffer coherency: ok
[ 0.002559] ftrace: allocating 19374 entries in 57 pages
[ 0.049873] CPU0: update cpu_capacity 1024
[ 0.049915] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 0.049932] [bcm2709_smp_prepare_cpus] enter
[ 0.050070] Setting up static identity map for 0x8240 - 0x8298
[ 0.129473] [bcm2709_boot_secondary] cpu:1 started (0) 17
[ 0.129831] [bcm2709_secondary_init] enter cpu:1
[ 0.129889] CPU1: update cpu_capacity 1024
[ 0.129898] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ 0.159508] [bcm2709_boot_secondary] cpu:2 started (0) 17
[ 0.159777] [bcm2709_secondary_init] enter cpu:2
[ 0.159810] CPU2: update cpu_capacity 1024
[ 0.159818] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ 0.189586] [bcm2709_boot_secondary] cpu:3 started (0) 17
[ 0.189839] [bcm2709_secondary_init] enter cpu:3
[ 0.189869] CPU3: update cpu_capacity 1024
[ 0.189878] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ 0.189969] Brought up 4 CPUs
[ 0.189998] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.190009] CPU: All CPU(s) started in HYP mode.
[ 0.190018] CPU: Virtualization extensions available.
[ 0.190901] devtmpfs: initialized
[ 0.201797] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.202279] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.203339] pinctrl core: initialized pinctrl subsystem
[ 0.204156] NET: Registered protocol family 16
[ 0.209550] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.239725] cpuidle: using governor ladder
[ 0.269753] cpuidle: using governor menu
[ 0.276646] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.276665] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.276845] Serial: AMBA PL011 UART driver
[ 0.277159] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[ 0.277846] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.351446] bcm2835-dma 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0x1
[ 0.353385] SCSI subsystem initialized
[ 0.353618] usbcore: registered new interface driver usbfs
[ 0.353742] usbcore: registered new interface driver hub
[ 0.353901] usbcore: registered new device driver usb
[ 0.359999] raspberrypi-firmware soc:firmware: Attached to firmware from 2016-01-29 13:52
[ 0.387189] clocksource: Switched to clocksource arch_sys_counter
[ 0.439398] FS-Cache: Loaded
[ 0.439852] CacheFiles: Loaded
[ 0.456339] NET: Registered protocol family 2
[ 0.457641] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.457779] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.457972] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.458102] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.458170] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.458522] NET: Registered protocol family 1
[ 0.459050] RPC: Registered named UNIX socket transport module.
[ 0.459069] RPC: Registered udp transport module.
[ 0.459079] RPC: Registered tcp transport module.
[ 0.459090] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.571670] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[ 0.574274] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.574463] audit: initializing netlink subsys (disabled)
[ 0.574539] audit: type=2000 audit(0.539:1): initialized
[ 0.589991] VFS: Disk quotas dquot_6.6.0
[ 0.590382] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.593156] FS-Cache: Netfs ‘nfs’ registered for caching
[ 0.594293] NFS: Registering the id_resolver key type
[ 0.594381] Key type id_resolver registered
[ 0.594395] Key type id_legacy registered
[ 0.597877] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 0.598081] io scheduler noop registered
[ 0.598647] io scheduler bfq registered (default)
[ 0.598660] BFQ I/O-scheduler version: v7r7
[ 0.601430] BCM2708FB: allocated DMA memory ee800000
[ 0.601479] BCM2708FB: allocated DMA channel 0 @ f3007000
[ 0.635612] Console: switching to colour frame buffer device 240x67
[ 1.630325] bcm2835-rng 3f104000.rng: hwrng registered
[ 1.630480] vc-cma: Videocore CMA driver
[ 1.630496] vc-cma: vc_cma_base = 0x00000000
[ 1.630509] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 1.630520] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 1.630839] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[ 1.651726] brd: module loaded
[ 1.663179] loop: module loaded
[ 1.664336] vchiq: vchiq_init_state: slot_zero = 0xae880000, is_master = 0
[ 1.666213] Loading iSCSI transport class v2.0-870.
[ 1.667123] usbcore: registered new interface driver smsc95xx
[ 1.667275] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.867665] Core Release: 2.80a
[ 1.867687] Setting default values for core params
[ 1.867713] Finished setting default values for core params
[ 2.068129] Using Buffer DMA mode
[ 2.068146] Periodic Transfer Interrupt Enhancement - disabled
[ 2.068157] Multiprocessor Interrupt Enhancement - disabled
[ 2.068168] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 2.068186] Dedicated Tx FIFOs mode
[ 2.068598] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xae814000 dma = 0xee814000 len=9024
[ 2.068639] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
[ 2.068686] dwc_otg: Microframe scheduler enabled
[ 2.068776] WARN::hcd_init_fiq:413: FIQ on core 1 at 0x80570454
[ 2.068796] WARN::hcd_init_fiq:414: FIQ ASM at 0x805707c4 length 36
[ 2.068817] WARN::hcd_init_fiq:439: MPHI regs_base at 0xaf87e000
[ 2.068906] dwc_otg 3f980000.usb: DWC OTG Controller
[ 2.068976] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 2.069032] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[ 2.069087] Init: Port Power? op_state=1
[ 2.069098] Init: Power Port (0)
[ 2.069420] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.069442] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.069459] usb usb1: Product: DWC OTG Controller
[ 2.069475] usb usb1: Manufacturer: Linux 4.4.0-1-osmc dwc_otg_hcd
[ 2.069491] usb usb1: SerialNumber: 3f980000.usb
[ 2.070653] hub 1-0:1.0: USB hub found
[ 2.070731] hub 1-0:1.0: 1 port detected
[ 2.071528] dwc_otg: FIQ enabled
[ 2.071543] dwc_otg: NAK holdoff enabled
[ 2.071555] dwc_otg: FIQ split-transaction FSM enabled
[ 2.071598] Module dwc_common_port init
[ 2.072006] usbcore: registered new interface driver usb-storage
[ 2.072395] mousedev: PS/2 mouse device common for all mice
[ 2.073031] usbcore: registered new interface driver usbtouchscreen
[ 2.073357] bcm2835-cpufreq: min=600000 max=900000
[ 2.075893] sdhci: Secure Digital Host Controller Interface driver
[ 2.075904] sdhci: Copyright(c) Pierre Ossman
[ 2.076272] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[ 2.076286] mmc-bcm2835 3f300000.mmc: DMA channels allocated
[ 2.107405] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.109011] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.112331] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.114641] usbcore: registered new interface driver usbhid
[ 2.114650] usbhid: USB HID core driver
[ 2.116161] Initializing XFRM netlink socket
[ 2.116200] NET: Registered protocol family 17
[ 2.116341] Key type dns_resolver registered
[ 2.118581] Registering SWP/SWPB emulation handler
[ 2.120610] registered taskstats version 1
[ 2.120793] vc-sm: Videocore shared memory driver
[ 2.120807] [vc_sm_connected_init]: start
[ 2.124535] [vc_sm_connected_init]: end - returning 0
[ 2.127749] Freeing unused kernel memory: 1788K (8099b000 - 80b5a000)
[ 2.145273] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.147607] mmc0: new high speed SDHC card at address 0001
[ 2.158571] mmcblk0: mmc0:0001 SD8GB 7.32 GiB
[ 2.160703] mmcblk0: p1 p2
[ 2.267416] Indeed it is in host mode hprt0 = 00021501
[ 2.346408] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.356696] fsck: E2fsck run: /bin/e2fsck -p -C 0 /dev/mmcblk0p2
[ 2.356943] fsck: Filesystem UUID: da97bea5-0646-4a52-bee8-c46cfc0f8aff
[ 2.357294] fsck: /dev/mmcblk0p2: clean, 25157/464208 files, 201045/1856256 blocks
[ 2.447336] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.447624] Indeed it is in host mode hprt0 = 00001101
[ 2.647547] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 2.647571] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.648509] hub 1-1:1.0: USB hub found
[ 2.648632] hub 1-1:1.0: 5 ports detected
[ 2.927312] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 3.027699] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 3.027733] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.031017] smsc95xx v1.0.4
[ 3.091319] smsc95xx 1-1.1:1.0 eth0: register ‘smsc95xx’ at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:c6:2b:a9
[ 3.327301] usb 1-1.2: new low-speed USB device number 4 using dwc_otg
[ 3.443686] usb 1-1.2: New USB device found, idVendor=04fc, idProduct=0538
[ 3.443722] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.443740] usb 1-1.2: Product: TURBO-X
[ 3.443756] usb 1-1.2: Manufacturer: MLK
[ 3.474882] input: MLK TURBO-X as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:04FC:0538.0001/input/input0
[ 3.528453] hid-generic 0003:04FC:0538.0001: input,hiddev0,hidraw0: USB HID v1.10 Mouse [MLK TURBO-X] on usb-3f980000.usb-1.2/input0
[ 3.607316] usb 1-1.3: new high-speed USB device number 5 using dwc_otg
[ 3.708261] usb 1-1.3: New USB device found, idVendor=0bda, idProduct=8179
[ 3.708295] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.708313] usb 1-1.3: Product: 802.11n NIC
[ 3.708329] usb 1-1.3: Manufacturer: Realtek
[ 3.708346] usb 1-1.3: SerialNumber: 0092C800B5DF
[ 4.570821] random: systemd urandom read with 78 bits of entropy available
[ 4.642423] NET: Registered protocol family 10
[ 5.251160] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[ 5.251458] systemd[1]: Found ordering cycle on basic.target/start
[ 5.251488] systemd[1]: Found dependency on sysinit.target/start
[ 5.251516] systemd[1]: Found dependency on kbd.service/start
[ 5.251542] systemd[1]: Found dependency on remote-fs.target/start
[ 5.251567] systemd[1]: Found dependency on remote-fs-pre.target/start
[ 5.251593] systemd[1]: Found dependency on connman.service/start
[ 5.251617] systemd[1]: Found dependency on dbus.service/start
[ 5.251641] systemd[1]: Found dependency on basic.target/start
[ 5.251667] systemd[1]: Breaking ordering cycle by deleting job kbd.service/start
[ 5.251697] systemd[1]: Job kbd.service/start deleted to break ordering cycle starting with basic.target/start
[ 5.252057] systemd[1]: Found ordering cycle on basic.target/start
[ 5.252090] systemd[1]: Found dependency on sysinit.target/start
[ 5.252118] systemd[1]: Found dependency on rpcbind.service/start
[ 5.252144] systemd[1]: Found dependency on network-online.target/start
[ 5.252169] systemd[1]: Found dependency on network.target/start
[ 5.252194] systemd[1]: Found dependency on connman.service/start
[ 5.252219] systemd[1]: Found dependency on dbus.service/start
[ 5.252243] systemd[1]: Found dependency on basic.target/start
[ 5.252268] systemd[1]: Breaking ordering cycle by deleting job rpcbind.service/start
[ 5.252298] systemd[1]: Job rpcbind.service/start deleted to break ordering cycle starting with basic.target/start
[ 5.587410] fuse init (API version 7.23)
[ 5.602578] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 5.964386] systemd-udevd[180]: starting version 215
[ 6.231510] lirc_dev: IR Remote Control driver registered, major 244
[ 6.240397] lirc_rpi: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.335349] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[ 6.337564] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 6.891365] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 6.988942] r8188eu: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.000842] Chip Version Info: CHIP_8188E_Normal_Chip_TSMC_A_CUT_1T1R_RomVer(0)
[ 7.023161] random: nonblocking pool is initialized
[ 7.029055] usbcore: registered new interface driver r8188eu
[ 7.197272] lirc_rpi: auto-detected active high receiver on GPIO pin 18
[ 7.197658] platform lirc_rpi: lirc_dev: driver lirc_rpi registered at minor = 0
[ 7.197671] lirc_rpi: driver registered!
[ 7.776672] input: lircd as /devices/virtual/input/input1
[ 7.984092] systemd-journald[156]: Received request to flush runtime journal from PID 1
[ 8.529611] smsc95xx 1-1.1:1.0 eth0: hardware isn’t capable of remote wakeup
[ 8.529859] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9.417689] MAC Address = 00:92:c8:00:b5:df
[ 9.420418] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 13.211379] Console: switching to colour dummy device 80x30
[ 36.882524] Bluetooth: Core ver 2.21
[ 36.884692] NET: Registered protocol family 31
[ 36.884739] Bluetooth: HCI device and connection manager initialized
[ 36.884786] Bluetooth: HCI socket layer initialized
[ 36.884820] Bluetooth: L2CAP socket layer initialized
[ 36.884918] Bluetooth: SCO socket layer initialized
[ 36.934141] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 36.934172] Bluetooth: BNEP filters: protocol multicast
[ 36.934207] Bluetooth: BNEP socket layer initialized
[ 667.700355] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 667.711092] smsc95indent preformatted text by 4 spacesxx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
[ 667.736816] 8021q: 802.1Q VLAN Support v1.8``
[ 1402.545534] R8188EU: ERROR indicate disassoc
[ 1405.803670] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 1457.949413] Console: switching to colour frame buffer device 240x67
[ 1470.693481] Console: switching to colour dummy device 80x30
[ 1487.663542] Console: switching to colour frame buffer device 240x67
[ 1499.866040] Console: switching to colour dummy device 80x30
[ 1562.607339] R8188EU: ERROR indicate disassoc
[ 1566.814711] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 2421.269739] smsc95xx 1-1.1:1.0 eth0: hardware isn’t capable of remote wakeup
[ 2428.762343] R8188EU: ERROR indicate disassoc
[ 2431.387698] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 2488.843070] smsc95xx 1-1.1:1.0 eth0: hardware isn’t capable of remote wakeup
[ 2490.400811] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
Should i compile from scratch the driver for 8188eu chip?
I would appreciate some help here.
Thank you
