Driver support for Archer T2U Plus (wireless usb adapter)?
I just got OSMC running today on I believe the latest kernel (4.19.122-1-osmc) but my wireless adapter doesn’t seem to connect. I’m using an RPi 3B+ and this adapter was working just fine out of the box on my last installation of LibreElec.
Does anyone have anymore information on how I might get it working with OSMC?
Adapter
If you search here you could find several post of T2U (maybe not +).
I guess your best bet is to check on your libreelec install which driver is used there and also the output of lsusb and post the results here.
https://discourse.osmc.tv/search?q=T2U%20order%3Alatest
According to this, it uses the RTL8811AU chipset.
You might need to build the driver yourself. It’s possible that the rtl8812au driver will also work. I can get GitHub - zebulon2/rtl8812au: RTL8812AU/21AU Driver for Linux to compile, though I have no idea if it’ll work with your device.
osmc@osmc:~/rtl8812au$ make ARCH=arm
make ARCH=arm CROSS_COMPILE= -C /lib/modules/4.19.122-1-osmc/build M=/home/osmc/rtl8812au  modules
make[1]: Entering directory '/usr/src/rbp2-headers-4.19.122-1-osmc'
<snip>
  Building modules, stage 2.
  MODPOST 1 modules
  CC      /home/osmc/rtl8812au/8812au.mod.o
  LD [M]  /home/osmc/rtl8812au/8812au.ko
make[1]: Leaving directory '/usr/src/rbp2-headers-4.19.122-1-osmc'
osmc@osmc:~/rtl8812au$ modinfo 8812au.ko
filename:       /home/osmc/rtl8812au/8812au.ko
version:        v5.1.5_19247.20160830
author:         Realtek Semiconductor Corp.
description:    Realtek Wireless Lan Driver
license:        GPL
srcversion:     83B42C8630A364F0F3AD62C
alias:          usb:v0411p029Bd*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0BDApA811d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v056Ep4007d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0846p9052d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v2019pAB32d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0411p0242d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v056Ep400Fd*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v056Ep400Ed*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0E66p0023d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v2001p3318d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v2001p3314d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v04BBp0953d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v7392pA813d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v7392pA812d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v7392pA811d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0BDAp0823d*dc*dsc*dp*icFFiscFFipFFin*
alias:          usb:v0BDAp0820d*dc*dsc*dp*icFFiscFFipFFin*
alias:          usb:v0BDAp8822d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0BDAp0821d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0BDAp0811d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v148Fp9097d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v2604p0012d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v050Dp1109d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0411p025Dd*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v20F4p805Bd*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v2357p0122d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v2357p010Fd*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v2357p010Ed*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v2357p010Dd*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v2357p0103d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v2357p0101d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v13B1p003Fd*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v2001p3316d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v2001p3315d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v07B8p8812d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v2019pAB30d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v1740p0100d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v1058p0632d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v2001p3313d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0586p3426d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0E66p0022d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0B05p17D2d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0409p0408d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0789p016Ed*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v04BBp0952d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0DF6p0074d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v7392pA822d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v2001p330Ed*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v050Dp1106d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0BDAp881Cd*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0BDAp881Bd*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0BDAp881Ad*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0BDAp8812d*dc*dsc*dp*ic*isc*ip*in*
depends:        cfg80211
vermagic:       4.19.122-1-osmc SMP preempt mod_unload modversions ARMv7 p2v8
parm:           rtw_ips_mode:The default IPS mode (int)
parm:           rtw_usb_rxagg_mode:int
parm:           rtw_drv_log_level:set log level when insert driver module, default log level is _DRV_INFO_ = 4 (uint)
parm:           rtw_tx_bw_mode:The max tx bw for 2.4G and 5G. format is the same as rtw_bw_mode (uint)
parm:           rtw_country_code:The default country code (in alpha2) (charp)
parm:           rtw_channel_plan:The default chplan ID when rtw_alpha2 is not specified or valid (int)
parm:           rtw_excl_chs:exclusive channel array (array of uint)
parm:           rtw_force_igi_lb:force IGI low-bound, 0:no specified (int)
parm:           rtw_qos_opt_enable:int
parm:           ifname:The default name to allocate for first interface (charp)
parm:           if2name:The default name to allocate for second interface (charp)
parm:           rtw_pwrtrim_enable:int
parm:           rtw_initmac:charp
parm:           rtw_special_rf_path:int
parm:           rtw_chip_version:int
parm:           rtw_rfintfs:int
parm:           rtw_lbkmode:int
parm:           rtw_network_mode:int
parm:           rtw_channel:int
parm:           rtw_mp_mode:int
parm:           rtw_wmm_enable:int
parm:           rtw_vrtl_carrier_sense:int
parm:           rtw_vcs_type:int
parm:           rtw_busy_thresh:int
parm:           rtw_ht_enable:int
parm:           rtw_bw_mode:int
parm:           rtw_ampdu_enable:int
parm:           rtw_rx_stbc:int
parm:           rtw_ampdu_amsdu:int
parm:           rtw_vht_enable:int
parm:           rtw_beamform_cap:int
parm:           rtw_lowrate_two_xmit:int
parm:           rtw_rf_config:int
parm:           rtw_power_mgnt:int
parm:           rtw_smart_ps:int
parm:           rtw_low_power:int
parm:           rtw_wifi_spec:int
parm:           rtw_full_ch_in_p2p_handshake:int
parm:           rtw_antdiv_cfg:int
parm:           rtw_antdiv_type:int
parm:           rtw_drv_ant_band_switch:int
parm:           rtw_switch_usb_mode:int
parm:           rtw_enusbss:int
parm:           rtw_hwpdn_mode:int
parm:           rtw_hwpwrp_detect:int
parm:           rtw_hw_wps_pbc:int
parm:           rtw_check_hw_status:int
parm:           rtw_max_roaming_times:The max roaming times to try (uint)
parm:           rtw_mc2u_disable:int
parm:           rtw_80211d:Enable 802.11d mechanism (int)
parm:           rtw_notch_filter:0:Disable, 1:Enable, 2:Enable only for P2P (uint)
parm:           rtw_led_enable:Enable status LED (int)
parm:           rtw_hiq_filter:0:allow all, 1:allow special, 2:deny all (uint)
parm:           rtw_adaptivity_en:0:disable, 1:enable (uint)
parm:           rtw_adaptivity_mode:0:normal, 1:carrier sense (uint)
parm:           rtw_adaptivity_dml:0:disable, 1:enable (uint)
parm:           rtw_adaptivity_dc_backoff:DC backoff for Adaptivity (uint)
parm:           rtw_adaptivity_th_l2h_ini:TH_L2H_ini for Adaptivity (int)
parm:           rtw_adaptivity_th_edcca_hl_diff:TH_EDCCA_HL_diff for Adaptivity (int)
parm:           rtw_amplifier_type_2g:BIT3:2G ext-PA, BIT4:2G ext-LNA (uint)
parm:           rtw_amplifier_type_5g:BIT6:5G ext-PA, BIT7:5G ext-LNA (uint)
parm:           rtw_RFE_type:default init value:64 (uint)
parm:           rtw_powertracking_type:default init value:64 (uint)
parm:           rtw_GLNA_type:default init value:0 (uint)
parm:           rtw_TxBBSwing_2G:default init value:0xFF (uint)
parm:           rtw_TxBBSwing_5G:default init value:0xFF (uint)
parm:           rtw_OffEfuseMask:default open Efuse Mask value:0 (uint)
parm:           rtw_FileMaskEfuse:default drv Mask Efuse value:0 (uint)
parm:           rtw_rxgain_offset_2g:default RF Gain 2G Offset value:0 (uint)
parm:           rtw_rxgain_offset_5gl:default RF Gain 5GL Offset value:0 (uint)
parm:           rtw_rxgain_offset_5gh:uint
parm:           rtw_rxgain_offset_5gm:default RF Gain 5GM Offset value:0 (uint)
parm:           rtw_pll_ref_clk_sel:force pll_ref_clk_sel, 0xF:use autoload value (uint)
parm:           rtw_tx_pwr_lmt_enable:0:Disable, 1:Enable, 2: Depend on efuse (int)
parm:           rtw_tx_pwr_by_rate:0:Disable, 1:Enable, 2: Depend on efuse (int)
parm:           rtw_target_tx_pwr_2g_a:2.4G target tx power (unit:dBm) of RF path A for each rate section, should match the real calibrate power, -1: undefined (array of int)
parm:           rtw_target_tx_pwr_2g_b:2.4G target tx power (unit:dBm) of RF path B for each rate section, should match the real calibrate power, -1: undefined (array of int)
parm:           rtw_target_tx_pwr_2g_c:2.4G target tx power (unit:dBm) of RF path C for each rate section, should match the real calibrate power, -1: undefined (array of int)
parm:           rtw_target_tx_pwr_2g_d:2.4G target tx power (unit:dBm) of RF path D for each rate section, should match the real calibrate power, -1: undefined (array of int)
parm:           rtw_target_tx_pwr_5g_a:5G target tx power (unit:dBm) of RF path A for each rate section, should match the real calibrate power, -1: undefined (array of int)
parm:           rtw_target_tx_pwr_5g_b:5G target tx power (unit:dBm) of RF path B for each rate section, should match the real calibrate power, -1: undefined (array of int)
parm:           rtw_target_tx_pwr_5g_c:5G target tx power (unit:dBm) of RF path C for each rate section, should match the real calibrate power, -1: undefined (array of int)
parm:           rtw_target_tx_pwr_5g_d:5G target tx power (unit:dBm) of RF path D for each rate section, should match the real calibrate power, -1: undefined (array of int)
parm:           rtw_phy_file_path:The path of phy parameter (charp)
parm:           rtw_load_phy_file:PHY File Bit Map (int)
parm:           rtw_decrypt_phy_file:Enable Decrypt PHY File (int)
You’ll probably need to modify the headers, as detailed here.
Thanks for the help. So I tried to go about building the driver myself but I am still not finding any success. I tried to modify the headers too and I’ve gotten to the point where these are my results:
make[1]: *** No rule to make target 'modules'.  Stop.
Makefile:1870: recipe for target 'modules' failed
make: *** [modules] Error 2
I’m not sure how to go any further. I’m planning to reinstall LibreElec as
fzinken
mentions to see which driver was giving me positive results and I’ll report back.
Running lsmod on LE should let you know which module it uses.
Just have it on a second SD Card then you can easier compare if more details needed.
Ok so I just reinstalled LibreELEC and this is what I get from lsusb:
LibreELEC:~ # lsusb
Bus 001 Device 006: ID 2357:0120 TP-Link
Bus 001 Device 005: ID 0c40:7a1c
Bus 001 Device 004: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
System info tells me LibreELEC (9.2.3) is running kernel 4.19.122.
Just looking around in /lib/modules/ shows a folder “RTL8812AU” which I assume is the driver for my adapter. Excuse me if this is a silly question, but how can I get this in my OSMC installation? I tried a few methods from other forum posts but no luck as of yet.
Thanks. These are my results:
LibreELEC:~ # lsmod
Module                  Size  Used by
hci_uart               40960  1
btbcm                  16384  1 hci_uart
serdev                 16384  1 hci_uart
bluetooth             438272  23 hci_uart,btbcm
ecdh_generic           28672  2 bluetooth
8812au               1363968  0
brcmfmac              204800  0
brcmutil               16384  1 brcmfmac
cfg80211              512000  2 8812au,brcmfmac
snd_usb_audio         167936  0
snd_usbmidi_lib        28672  1 snd_usb_audio
snd_hwdep              16384  1 snd_usb_audio
snd_pcm                77824  1 snd_usb_audio
snd_timer              28672  1 snd_pcm
snd_rawmidi            28672  1 snd_usbmidi_lib
snd                    53248  6 snd_hwdep,snd_usb_audio,snd_timer,snd_rawmidi,snd_usbmidi_lib,snd_pcm
rfkill                 24576  6 bluetooth,cfg80211
bcm2835_gpiomem        16384  0
fixed                  16384  0
wireguard             143360  0
ip6_udp_tunnel         16384  1 wireguard
It definitely seems like 8812au is what I’m looking for!
That module will be re-added to a new kernel in OSMC soon.
That’s great to hear. Looking forward to using this adapter asap as my only internet method is wifi for the time being.
It’s not clear why the build failed. If you have installed the headers package and created the symbolic link:
sudo ln -s /usr/src/rbp2-headers-$(uname -r) /lib/modules/$(uname -r)/build
it should have built correctly.
However, I see that the T2U Plus has a VID:PID of 2357:0120 but the driver I built doesn’t have this combination, the closest being 2357:0122. There is a workaround to this issue but if OSMC will be including the 8812au driver in the next release, it’s probably worth waiting for it.
I must have made a few errors along the way before getting to that point. Nonetheless, I appreciate the help and will be waiting patiently for the next release.
