I have some films here in DTS:X - but they don’t play back in DTX:X.
What’s the mistake?
What’s the mistake?
Is it enabled in audio settings? Does your setup allow it? Samsung and Lg tvs unlikely will work with it.
@Cyberagent might want to check this wiki
Everything is connected correctly to the Yamaha AV 3070.
Some films also work in DTS:X.
But other films that I tested above in the protocol do not work. For example, they are only played back in DTS-HD MA.
Your Vero doesn’t do anything to the stream, if you use passthrough. Whether the AVR then recognizes the stream’s DTS:X related metadata and plays it as such, is only up to the AVR, I’m afraid.
Looking through your log your settings appear to be fine but I have doubts about your files.
I see attempts to playback the movie The Beekeeper (2024) which the file meta data claims has a German DTS: X track but that may be inaccurate.
From what I can see, that movie in all regions has Atmos, not DTS:X.
So I get the feeling that your movie file is incorrect.
2024-04-21 17:28:51.171 T:3082 info <general>: ffmpeg[0xb37f9420]: Stream #0:1(ger): Audio: dts (DTS-HD MA), 48000 Hz, 8 channels (FL+FR+FC+LFE+SL+SR+TFL+TFR), s32p (24 bit) (default) (forced)
2024-04-21 17:28:51.171 T:3082 info <general>: ffmpeg[0xb37f9420]: Metadata:
2024-04-21 17:28:51.171 T:3082 info <general>: ffmpeg[0xb37f9420]: title : German DTS X 7.1 by Mortadella
2024-04-21 17:28:51.171 T:3082 info <general>: ffmpeg[0xb37f9420]: BPS : 5246181
2024-04-21 17:28:51.171 T:3082 info <general>: ffmpeg[0xb37f9420]: DURATION : 01:45:07.627000000
2024-04-21 17:28:51.171 T:3082 info <general>: ffmpeg[0xb37f9420]: NUMBER_OF_FRAMES: 591340
2024-04-21 17:28:51.171 T:3082 info <general>: ffmpeg[0xb37f9420]: NUMBER_OF_BYTES : 4136369152
2024-04-21 17:28:51.171 T:3082 info <general>: ffmpeg[0xb37f9420]: _STATISTICS_WRITING_APP: mkvmerge v83.0 ('Circle Of Friends') 64-bit
2024-04-21 17:28:51.171 T:3082 info <general>: ffmpeg[0xb37f9420]: _STATISTICS_WRITING_DATE_UTC: 2024-04-21 11:48:13
2024-04-21 17:28:51.171 T:3082 info <general>: ffmpeg[0xb37f9420]: _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
Same thing with your Dune file:
2024-04-21 17:27:54.152 T:3017 info <general>: ffmpeg[0xb1e6a650]: Stream #0:1(ger): Audio: dts (DTS-HD HRA), 48000 Hz, 8 channels (FL+FR+FC+LFE+SL+SR+TFL+TFR), fltp (default) (forced)
2024-04-21 17:27:54.152 T:3017 info <general>: ffmpeg[0xb1e6a650]: Metadata:
2024-04-21 17:27:54.152 T:3017 info <general>: ffmpeg[0xb1e6a650]: title : Deutsch DTS X 7.1 v2 by Mortadella
2024-04-21 17:27:54.152 T:3017 info <general>: ffmpeg[0xb1e6a650]: BPS : 5375999
2024-04-21 17:27:54.152 T:3017 info <general>: ffmpeg[0xb1e6a650]: DURATION : 02:45:40.022000000
2024-04-21 17:27:54.152 T:3017 info <general>: ffmpeg[0xb1e6a650]: NUMBER_OF_FRAMES: 931877
2024-04-21 17:27:54.152 T:3017 info <general>: ffmpeg[0xb1e6a650]: NUMBER_OF_BYTES : 6679694336
2024-04-21 17:27:54.152 T:3017 info <general>: ffmpeg[0xb1e6a650]: _STATISTICS_WRITING_APP: mkvmerge v83.0 ('Circle Of Friends') 64-bit
2024-04-21 17:27:54.152 T:3017 info <general>: ffmpeg[0xb1e6a650]: _STATISTICS_WRITING_DATE_UTC: 2024-04-21 10:52:55
2024-04-21 17:27:54.152 T:3017 info <general>: ffmpeg[0xb1e6a650]: _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
Both movies are Dolby Atmos movies, not DTS: X movies.
The meta data says “DTS X 7.1 by Mortadella” whatever that means.
Sounds like some guy on the internet trying to convert Atmos tracks to DTS: X tracks and failing to me.
