I want to use a remote desktop like using a thin client . But the thin client can not work with dual display.
You can tell me how to set my raspberry to use dual display?
could you tell me what files should I change ?
Thanks, we need yours help
@popcornmix You know raspberry well.
Could you help me, please?
I use vga666 but only works one screen. if I use vga, the HDMI connection stops working.
I want to use a raspberry like a thin client . But the thin client can not work with dual display.
thanks so much,
Not really understanding the question. What are you hoping to run on each display?
How does “thin client” fit in with OSMC?
Excuse my english @popcornmix
I use NOOBS.
I want to connect to a remote desktop. And using dual display in my raspbery.
I want to use dual display with rdesktop.
Using the program omxplayer. I can send a video signal by hdmi.
I want to know if it is possible to use dual display with rdesktop . Because in my company we want to change thin client by raspberry.
you know something about it?
thanks so much !
So nothing to do with OSMC?
I see you’ve also posted in raspberry pi forum, which would be a more suitable place for questions.
@popcornmix
I saw on a forum that you said that vga666 worked . I thought you could help me. I just want to use dual display with my raspberry but it doesn`t work.
thanks
@popcornmix
I think it is impossible to use dual display. I’ve tried 5 days and it is impossible .
The documentation states that the software for this is not quite there and will eat a lot of ram.
