Okay, I found the solution.
In short, that is:
- Without disabling connman, using wpa_supplicant to dial 802.1X on eth0
- Set static IP manually for eth1 (the port connecting downstream devices)
- Don’t use
tether
, but use DHCP softwares instead. I used udhcpd on eth1
- Fine adjust and set auto script if necessary
Detailed version (You can ignore this if you understand the above implements):
First, here is something I encountered during this configuration:
Tethering one ethernet connection to another is NOT working, because it will end up with both interfaces broadcasting DHCP to whatever the device they connect with. In this case, I cannot use any of them to dial my 802.1X wired interface.
I failed to disable connman. Before disabling that, I first installed network-manager, then I disabled connman by “systemctl disable connman.service” followed by “systemctl mask connman.service”. This will prevent connman to takeover network connections. However, this configuration will cause a problem and when I use “ifconfig” to look the system, there was no network interface (except “lo”) .
Therefore I thought I cannot disable connman for it takes over the core of networking system. Instead, I tried the following and they worked:
Solution:
- Dial 802.1X using wpa_supplicant: wpa_supplicant complete edition is embedded within OSMC, which saved me a lot of trouble to uninstall its mini version and reinstall the complete one (this happens in some router linux systems). First prepare the wpa_supplicant.conf file and adjust it to your very environment. The file should be like this
ctrl_interface=/var/run/wpa_supplicant network={ proto=WPA key_mgmt=WPA-EAP pairwise=CCMP eap=PEAP ca_cert="/usr/share/cacertificates/mozilla/AddTrust_External_Root.crt" identity="username@example.com" password="mySecret" phase2="auth=MSCHAPV2" }
Remember to adjust it before you can use that!!! And adjustment of this file is the most important step if you’re trying to connect a 802.1X connection.
Then use
sudo wpa_supplicant -Dwired -ieth0 -c /etc/wpa_supplicant/wpa_supplicant.conf
to start the 802.1X connection. " /etc/wpa_supplicant/wpa_supplicant.conf" is the pathway where you store 802.1X conf file.
A successful dial ends up with text like
EAP-MSCHAPV2: Authentication succeeded EAP-TLV: TLV Result - Success - EAP-TLV/Phase2 Completed eth0: CTRL-EVENT-EAP-SUCCESS EAP authentication completed successfully
2.After that, you probably still cannot get access to the Internet yet (I check my connection by sudo apt-get update
), since connman wrongly places priority of your two connections.
To correct that, you need first enter connmanctl
Then first enter services
to check your connection names, and identify whether the 802.1X is on the first priority. If not, you may want to enter
move-before your_802.1X_service_name another_wired_interface_service_name
to change that.
After that, OSMC should be able to access the Internet through 802.1X.
3.Set the other connection (the one you want to connect with downstream device instead of the one you used to dial 802.1X), give it a static IP address to become a host of downstream DHCP broadcast. This step should also be operated inside connmanctl
interface:
this line should do the trick config ethernet_interface_service_name --ipv4 manual 192.168.3.1 255.255.255.0 192.168.3.1
This line adjust that interface with static IP of 192.168.3.1
, and netmask of 255.255.255.0
, and router address of 192.168.3.1
(itself plays the role of router for the downstream devices)
4.The next step is to manually setup DHCP service WITHOUT using tether
This can be done by first installing DHCP controlling softwares (I used udhcpd): sudo apt-get -y install udhcpd
Then sudo nano /etc/default/udhcpd
, and place the symble “#” before the line DHCPD_ENABLED="no"
, this will enable udhcpd software.
Next, change udhcpd services as you desired, command is sudo nano /etc/udhcpd.conf
There are several things you may want to modify in this file:
// Range of dhcp service,
start 192.168.3.20 end 192.168.3.29
//For me the downstream device is only one, so this range can be very small
//Interface which you want to use dhcp, in this very case, my usb ethernet port is “eth1”, and I use that to connect to the WAN port of downstream devices
interface eth1
//Other things
opt dns 8.8.8.8 opt subnet 255.255.255.0 opt router 192.168.3.1 //Better match this with dhcp range you're broadcasting option lease 28800
Then you can start this service by sudo service udhcpd restart
and add this to auto boot-up services by sudo update-rc.d udhcpd defaults
5.Enabling IP FORWARD
Enter sudo nano /etc/sysctl.conf
and remove the symble “#” before the line net.ipv4.ip_forward=1
6.Enableing NAT Functions
sudo iptables -F sudo iptables -F -t nat sudo iptables -t nat -A POSTROUTING -o eth0 -j MASQUERADE sudo iptables -A FORWARD -i eth0 -o eth1 -m state --state RELATED,ESTABLISHED -j ACCEPT sudo iptables -A FORWARD -i wlan0 -o eht1 -j ACCEPT
Then save above configuration
sudo bash -c 'iptables-save > /etc/network/iptables' sudo iptables-restore < /etc/network/iptables
And make them automatically run during boot:
First sudo nano /etc/rc.local
Then add this line sudo iptables-restore < /etc/network/iptables
above exit 0
7.That should be all, now both OSMC and its downstream device should be able to get access to the Internet. Of course you may want to write down some script for the following two steps, because they need manual execution every boots: 1. 802.1X dial 2.connmal interface priority
Thanks for anyone who gave me help and suggestion on this post!
