Could not find an answer elsewhere. Searched for “smb”.
Using Raspberry Pi 2 B. Had my media files on hdd connected to
Pi via powered usb hub. Everything worked fine. Then plugged hdd into router. Removed all old sources. Added new sources. Got duplicate entries on all TV shows and music db but not on movies. Deleted DBs in userdata and rescanned. Same result. Re-installed osmc. Same result. Problem not showstopper but would welcome a fix. I’ve also tried cleaning library with no result. In duplicate entries, only one entry links to actual files. Will take a look at db entries when I get a minute.
I’m a fairly vanilla user but so far, osmc looks good! Keep up the good work.
Look at a debug log that contains the scraping of the source. This should indicate what is being counted twice? Also, I would put my eyes on sources.xml to make sure everything is as it should be there.
Are there any samples in the folder?
I’ve seen that result in duplicate entries in the database for me. Only solution was to remove the samples. After that doing a Cleaning of the library, but in some cases I needed to remove the source, do a cleaning of the library and then adding the source and doing a new scrape.
Renesdk, no samples in folder. Also removed Apple hidden files. No joy.
ActionA,
Haven’t had a chance to look at DB yet, but here’s another clue, hopefully.
My source is called tv.
If I start at top level VIDEOS - Files - tv - episode names only appear once
If I start at top level TV SHOWS then every episode name appears twice!
Will follow up if I get more.
I am new to OSMC & installed it on a RPi2. I can’t seem to install rsync & get “E: Unable to locate package rsync”. I tried to follow the link above but could not find file sources.xml. Any help would be appreciated. Thanks
