I saw some recent progress regarding the DVB situation for the vero 4k. That’s great to hear, many thanks!
Unfortunately, my DVB-S tuner (Terratec Cinnergy S2 USB-Box) still doesn’t work.
Following this advice, I’m starting a new thread with relevant logs (let me know, if I’m missing some).
I’ve just updated to the latest stretch-devel kernel 3.14.29-100-osmc.
After booting the vero4k, I’ve plugged in the DVB-S tuner. I don’t see a device at tvheadend’s web configuration, so I can’t use the tuner.
> sudo journalctl -f
Jun 24 18:14:12 fernseher kernel: usb 1-1: new full-speed USB device number 3 using xhci-hcd
Jun 24 18:14:12 fernseher kernel: usb 1-1: device descriptor read/64, error -71
Jun 24 18:14:12 fernseher kernel: xhci-hcd xhci-hcd.0.auto: Setup ERROR: setup context command for slot 2.
Jun 24 18:14:12 fernseher kernel: usb 1-1: new high-speed USB device number 4 using xhci-hcd
Jun 24 18:14:12 fernseher kernel: usb 1-1: New USB device found, idVendor=0ccd, idProduct=0105
Jun 24 18:14:12 fernseher kernel: usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jun 24 18:14:12 fernseher kernel: usb 1-1: Product: TERRATEC USB Tuner
Jun 24 18:14:12 fernseher kernel: usb 1-1: Manufacturer: Tevii
Jun 24 18:14:12 fernseher kernel: usb 1-1: SerialNumber: 000000031
Jun 24 18:14:12 fernseher kernel: WARNING: You are using an experimental version of the media stack.
As the driver is backported to an older kernel, it doesn't offer
enough quality for its usage in production.
Use it with care.
Latest git patches (needed if you report a bug to linux-media@vger.kernel.org):
9eeb0ed0f30938f31a3d9135a88b9502192c18dd [media] mtk-vcodec: fix build warnings without DEBUG
0d1270df836fe9f5cc7e8001b7372ca4fa3f00f6 [media] zd1301: fix building interface driver without demodulator
9165ba166cac5e8c9abda2012ea37cc3430c0b14 [media] usbtv: add sharpness control
Jun 24 18:14:12 fernseher kernel: usb 1-1: dvb_usb_v2: found a 'Terratec Cinergy S2 Rev.4' in warm state
Jun 24 18:14:12 fernseher kernel: usb 1-1: dvb_usb_v2: will pass the complete MPEG2 transport stream to the software demuxer
Jun 24 18:14:12 fernseher kernel: dvbdev: DVB: registering new adapter (Terratec Cinergy S2 Rev.4)
Jun 24 18:14:12 fernseher kernel: usb 1-1: media controller created
Jun 24 18:14:12 fernseher kernel: usb 1-1: dvb_usb_v2: MAC address: ff:ff:ff:ff:ff:ff
Jun 24 18:14:12 fernseher kernel: dvbdev: dvb_create_media_entity: media entity 'dvb-demux' registered.
Jun 24 18:14:12 fernseher kernel: DVB: Unable to find symbol m88ds3103_attach()
Jun 24 18:14:12 fernseher kernel: usb 1-1: dvbsky_s960_attach fail.
Jun 24 18:14:12 fernseher kernel: usbcore: registered new interface driver dvb_usb_dvbsky
Jun 24 18:14:12 fernseher kernel: dw2102: su3000_identify_state
Jun 24 18:14:12 fernseher kernel: dvb-usb: found a 'Terratec Cinergy S2 USB BOX' in warm state.
Jun 24 18:14:12 fernseher kernel: dw2102: su3000_power_ctrl: 1, initialized 0
Jun 24 18:14:12 fernseher kernel: dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
Jun 24 18:14:12 fernseher kernel: dvbdev: DVB: registering new adapter (Terratec Cinergy S2 USB BOX)
Jun 24 18:14:12 fernseher kernel: dvb-usb: MAC address: bc:ea:2b:46:13:a5
Jun 24 18:14:13 fernseher kernel: dvb-usb: no frontend was attached by 'Terratec Cinergy S2 USB BOX'
Jun 24 18:14:13 fernseher kernel: rc rc1: IR-receiver inside an USB DVB receiver as /devices/c9000000.dwc3/xhci-hcd.0.auto/usb1/1-1/rc/rc1
Jun 24 18:14:13 fernseher kernel: Registered IR keymap rc-tt-1500
Jun 24 18:14:13 fernseher kernel: input: IR-receiver inside an USB DVB receiver as /devices/c9000000.dwc3/xhci-hcd.0.auto/usb1/1-1/rc/rc1/input10
Jun 24 18:14:13 fernseher kernel: dvb-usb: schedule remote query interval to 250 msecs.
Jun 24 18:14:13 fernseher kernel: dw2102: su3000_power_ctrl: 0, initialized 1
Jun 24 18:14:13 fernseher kernel: dvb-usb: Terratec Cinergy S2 USB BOX successfully initialized and connected.
Jun 24 18:14:13 fernseher kernel: usbcore: registered new interface driver dw2102
Jun 24 18:14:15 fernseher kernel: dvb-usb: recv bulk message failed: -110
Jun 24 18:14:15 fernseher kernel: dw2102: i2c transfer failed.
> lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 002: ID 2252:1037
Bus 001 Device 004: ID 0ccd:0105 TerraTec Electronic GmbH
> dmesg | grep -i dvb
[ 128.590207] usb 1-1: dvb_usb_v2: found a 'Terratec Cinergy S2 Rev.4' in warm state
[ 128.592666] usb 1-1: dvb_usb_v2: will pass the complete MPEG2 transport stream to the software demuxer
[ 128.592713] dvbdev: DVB: registering new adapter (Terratec Cinergy S2 Rev.4)
[ 128.594000] usb 1-1: dvb_usb_v2: MAC address: ff:ff:ff:ff:ff:ff
[ 128.595038] dvbdev: dvb_create_media_entity: media entity 'dvb-demux' registered.
[ 128.599609] DVB: Unable to find symbol m88ds3103_attach()
[ 128.599627] usb 1-1: dvbsky_s960_attach fail.
[ 128.604890] usbcore: registered new interface driver dvb_usb_dvbsky
[ 128.661529] dvb-usb: found a 'Terratec Cinergy S2 USB BOX' in warm state.
[ 128.661788] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[ 128.661900] dvbdev: DVB: registering new adapter (Terratec Cinergy S2 USB BOX)
[ 128.665942] dvb-usb: MAC address: bc:ea:2b:46:13:a5
[ 128.666916] dvbdev: dvb_create_media_entity: media entity 'dvb-demux' registered.
[ 128.972445] dvb-usb: no frontend was attached by 'Terratec Cinergy S2 USB BOX'
[ 128.972661] rc rc1: IR-receiver inside an USB DVB receiver as /devices/c9000000.dwc3/xhci-hcd.0.auto/usb1/1-1/rc/rc1
[ 129.000322] input: IR-receiver inside an USB DVB receiver as /devices/c9000000.dwc3/xhci-hcd.0.auto/usb1/1-1/rc/rc1/input10
[ 129.000446] dvb-usb: schedule remote query interval to 250 msecs.
[ 129.000460] dvb-usb: Terratec Cinergy S2 USB BOX successfully initialized and connected.
[ 131.250139] dvb-usb: recv bulk message failed: -110
Looking forward to your suggestions!
silberzwiebel
