After recent update which I have applied yesterday, my DVB-T USB stick stopped working. The tuner was working properly over last 2 months with TVHeadend compiled according to the instruction on the forum. TVHeadend does not show any any adapters, and femon shows error:
osmc@osmc:~# femon -a 0
opening frontend failed: No such file or directory
Indeed, there is nothing related to dvb in /dev/, while it used to be there (I’m sure as I’ve checked it some time ago).
The tuner is
osmc@osmc:~# lsusb
Bus 001 Device 004: ID 048d:9006 Integrated Technology Express, Inc. IT9135 BDA Afatech DVB-T HDTV Dongle
Currently the dmesg shows:
osmc@osmc:~# dmesg | grep -i dvb
[ 2.525172] usb 1-1.3: Product: DVB-T TV Stick
[ 2.541234] input: ITE Technologies, Inc. DVB-T TV Stick as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3:1.1/0003:048D:9006.0001/input/input0
[ 2.541739] hid-generic 0003:048D:9006.0001: input,hidraw0: USB HID v1.01 Keyboard [ITE Technologies, Inc. DVB-T TV Stick] on usb-bcm2708_usb-1.3/input1
[ 7.997742] usb 1-1.3: dvb_usb_af9035: prechip_version=83 chip_version=01 chip_type=9135
[ 8.002430] usb 1-1.3: dvb_usb_v2: found a ‘ITE 9135(9006) Generic’ in warm state
[ 8.013615] usb 1-1.3: dvb_usb_af9035: [0] overriding tuner from 00 to 38
[ 8.015191] usb 1-1.3: dvb_usb_af9035: [1] overriding tuner from 00 to 38
[ 8.025071] usb 1-1.3: dvb_usb_v2: will pass the complete MPEG2 transport stream to the software demuxer
[ 8.025216] DVB: registering new adapter (ITE 9135(9006) Generic)
[ 8.079515] usb 1-1.3: DVB: registering adapter 0 frontend 0 (Afatech AF9033 (DVB-T))…
[ 8.121756] usb 1-1.3: dvb_usb_v2: will pass the complete MPEG2 transport stream to the software demuxer
[ 8.121892] DVB: registering new adapter (ITE 9135(9006) Generic)
[ 8.201038] usbcore: registered new interface driver dvb_usb_af9035
So there is no firmware loading message. But the firmware (original, delivered with OSMC) is out there:
osmc@osmc:~# ls -l /lib/firmware/ | grep -i 9135
-rw-r–r-- 1 root root 8128 lis 4 2014 dvb-usb-it9135-01.fw
-rw-r–r-- 1 root root 5834 lis 4 2014 dvb-usb-it9135-02.fw
And before recent update, the logs showed firmware being loaded and working properly:
2015-06-12T19:46:53+02:00 [ 2.524901] usb 1-1.3: Product: DVB-T TV Stick
2015-06-12T19:46:53+02:00 [ 2.524917] usb 1-1.3: Manufacturer: ITE Technologies, Inc.
2015-06-12T19:46:53+02:00 [ 2.541257] input: ITE Technologies, Inc. DVB-T TV Stick as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3:1.1/0003:048D:9006.0001/input/input0
2015-06-12T19:46:53+02:00 [ 2.541748] hid-generic 0003:048D:9006.0001: input,hidraw0: USB HID v1.01 Keyboard [ITE Technologies, Inc. DVB-T TV Stick] on usb-bcm2708_usb-1.3/input1
2015-06-12T19:46:53+02:00 [ 4.522025] random: systemd urandom read with 83 bits of entropy available
2015-06-12T19:46:53+02:00 [ 4.616493] NET: Registered protocol family 10
2015-06-12T19:46:53+02:00 [ 5.887873] fuse init (API version 7.23)
2015-06-12T19:46:53+02:00 [ 6.010371] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
2015-06-12T19:46:53+02:00 [ 7.727056] lirc_dev: IR Remote Control driver registered, major 246
2015-06-12T19:46:53+02:00 [ 7.757679] lirc_rpi: module is from the staging directory, the quality is unknown, you have been warned.
2015-06-12T19:46:53+02:00 [ 8.017120] usb 1-1.3: dvb_usb_af9035: prechip_version=83 chip_version=01 chip_type=9135
2015-06-12T19:46:53+02:00 [ 8.019334] usb 1-1.3: dvb_usb_v2: found a ‘ITE 9135(9006) Generic’ in cold state
2015-06-12T19:46:53+02:00 [ 8.053960] usb 1-1.3: dvb_usb_v2: downloading firmware from file ‘dvb-usb-it9135-01.fw’
2015-06-12T19:46:53+02:00 [ 8.730384] lirc_rpi: auto-detected active low receiver on GPIO pin 18
2015-06-12T19:46:53+02:00 [ 8.730851] lirc_rpi lirc_rpi: lirc_dev: driver lirc_rpi registered at minor = 0
2015-06-12T19:46:53+02:00 [ 8.730876] lirc_rpi: driver registered!
2015-06-12T19:46:53+02:00 [ 8.986571] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
2015-06-12T19:46:53+02:00 [ 9.050982] random: nonblocking pool is initialized
2015-06-12T19:46:53+02:00 [ 11.028843] usb 1-1.3: dvb_usb_af9035: firmware version=12.54.14.0
2015-06-12T19:46:53+02:00 [ 11.028914] usb 1-1.3: dvb_usb_v2: found a ‘ITE 9135(9006) Generic’ in warm state
2015-06-12T19:46:53+02:00 [ 11.034969] usb 1-1.3: dvb_usb_af9035: [0] overriding tuner from 00 to 38
2015-06-12T19:46:53+02:00 [ 11.036651] usb 1-1.3: dvb_usb_af9035: [1] overriding tuner from 00 to 38
2015-06-12T19:46:53+02:00 [ 11.049894] usb 1-1.3: dvb_usb_v2: will pass the complete MPEG2 transport stream to the software demuxer
Anyone has seen similar problem?
