[ 1178.890574] usb 1-1.2.4: dvb_usb_v2: downloading firmware from file 'dvb-usb-it9135-01.fw'
[ 1178.891109] usb 1-1.2.4: dvb_usb_af9035: too much data wlen=64 rlen=0
[ 1178.891401] dvb_usb_af9035: probe of 1-1.2.4:1.0 failed with error -22
This is what I get when trying to start the dvb-t stick with osmc alpha…
That’s an odd issue. I see a potential device mismatch between 9035 and 9135 there. Can you confirm what model of DVB stick you are trying to use and also upload some dmesg output?
It’s a technaxx S4 dvb-t stick and I use it all the time with raspbmc without any problems.
Here is some more dmesg output:
[ 401.809454] usb 1-1.2.4: New USB device found, idVendor=048d, idProduct=9005
[ 401.809495] usb 1-1.2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 401.809517] usb 1-1.2.4: Product: DVB-T TV Stick
[ 401.809536] usb 1-1.2.4: Manufacturer: ITE Technologies, Inc.
[ 401.819719] usb 1-1.2.4: dvb_usb_af9035: prechip_version=83 chip_version=01 chip_type=9135
[ 401.820246] usb 1-1.2.4: dvb_usb_v2: found a 'ITE 9135(9005) Generic' in cold state
[ 401.827770] usb 1-1.2.4: dvb_usb_v2: downloading firmware from file 'dvb-usb-it9135-01.fw'
[ 401.828291] usb 1-1.2.4: dvb_usb_af9035: too much data wlen=64 rlen=0
[ 401.828630] dvb_usb_af9035: probe of 1-1.2.4:1.0 failed with error -22
My guess would be that the firmware is not compatible with a 3.17 kernel then. I would suggest looking for a newer firmware from the vendor’s site. I have used get_dvb_firmware from the kernel to prepopulate the firmare.
