Yvan
19 September 2024 20:29
1
Hello All
I wanted to use my dvb t2 dongle on my old vero 4k. Tv Headend is installed and work with an m3 u file normally.
I wanted to use the dongle to receive the local dvb t2 stream in switzerland.
At the moment I am unable to configure any channels. To my understanding it is like i am unable to use dvb t2 channels
I have these adapters
It seems that I have some signal
I am sure that miss something but I am working on it since two days. so If you guys have any clue to help. i will really appreciate.
Have you seen this guide:
To watch broadcast (OTA or cable) TV on your OSMC device you need these:
a TV tuner attached via USB or a networked TV box
software ‘server’ to handle the tuning, retrieve OTA EPG and act as a PVR
an addon for Kodi which interfaces Kodi to the server
OSMC provides a USB tuner in the online Store, the TVHeadend server and the TVHeadend HTSP client to do all this. Here’s how to set it up.
Plug the tuner into a USB port and attach a good aerial or cable connection.
Make sure your device is co…
Regards Tom.
Make sure you select the Sony adapter as the main device as that is the demodulator capable of receiving DVB-T2
Can you also confirm you are on the latest version of OSMC?
Yvan
20 September 2024 06:15
4
Thank you for that. I I did not find it directly searching in the wiki. Maybe add it to the Main menu of the wiki as you are selling the dongle.
I am going to repeat these information and tell you if I have more success.
thanks
Yvan
20 September 2024 06:19
5
Yes I am using the latest version and I use the second sony adapter in the capture of screen above, the one written DVB -T#1
and thanks again for all the work you are doing, I am a proud user of one vero 4k , one vero 4k+ and one VERO V and I really enjoy them…
Yvan
21 September 2024 15:35
6
Which log file you want to see if I want to be sure the second adapter is working ?
the DVB t2
Rgds
Yvan
To get a better understanding of the problem you are experiencing we need more information from you. The best way to get this information is for you to upload logs that demonstrate your problem. You can learn more about how to submit a useful support request here .
Depending on the used skin you have to set the settings-level to standard or higher , in summary:
reproduce the issue
There is only one usable DVB-T2 tuner (it is not a dual tuner).
Yvan
22 September 2024 13:38
9
Here is the URL
https://paste.osmc.tv/eqaveyiqej
thank you for our help
Have you set your region and initiated a scan? I’m not sure where you are stuck
Yvan
22 September 2024 14:55
11
Yes, I tried twice to scan the mux under the Switzerland name.
Maybe I can try to scan the default mux ?
You can just scan everything in case the Swiss one is outdated.
Yvan
22 September 2024 16:45
15
I need to use the default mux ?
Yvan
24 September 2024 06:43
17
I think I have some problem to have a good signal. I will come back here when I will solve that on my side.
Thanks anyway
OK, let us know if we can help.
