I just receive my New Vero 4k but TVH doesn’t recognise my dvb-t2, so far It has worked propierly in my Raspberry Pi 3.
Vero4k lsusb:
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 001 Device 004: ID 0572:c689 Conexant Systems (Rockwell), Inc. Bus 001 Device 002: ID 2017:1688
Vero4k dmesg | grep “usb 1-2”
[ 3.167016] usb 1-2: new high-speed USB device number 3 using xhci-hcd
[ 3.307411] usb 1-2: New USB device found, idVendor=0572, idProduct=c689
[ 3.307422] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.307427] usb 1-2: Product: EyeTV Stick
[ 3.307432] usb 1-2: Manufacturer: Geniatech
[ 3.307437] usb 1-2: SerialNumber: 160421
[ 187.231754] usb 1-2: USB disconnect, device number 3
[ 191.444905] usb 1-2: new high-speed USB device number 4 using xhci-hcd
[ 191.585255] usb 1-2: New USB device found, idVendor=0572, idProduct=c689
[ 191.585266] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 191.585272] usb 1-2: Product: EyeTV Stick
[ 191.585277] usb 1-2: Manufacturer: Geniatech
[ 191.585282] usb 1-2: SerialNumber: 160421
You may be missing the correct firmware files. Have a look at dmesg on the Pi and see which files it’s loading, and copy those files across to /lib/firmware on vero. There are several versions of the firmware files for these sticks.
If that doesn’t work, 0572:c689 will have to be added to the drivers we build. Older versions of the stick were 0572:c688.
@sam_nazarko can usually do these things within days but I don’t know how busy he is. I can only suggest you use the Pi as the PVR server in the meantime and point the Vero’s PVR client at it if you are using Vero for everything else.
Thank you grahamh, I tried but after plug in the stick I have got:
osmc@osmc:~$ dmesg | grep dvb
[ 80.231732] usbcore: registered new interface driver dvb_usb_cxusb
[ 136.447930] dvb_usb_cxusb: probe of 1-2:1.0 failed with error -22
I restart the sistem and I had not out for dmesg |grep dvb.
Then I have got this with dmesg | grep usb:
[ 3.166825] usb 1-2: new high-speed USB device number 3 using xhci-hcd
[ 3.307272] usb 1-2: New USB device found, idVendor=0572, idProduct=c689
[ 3.307283] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.307288] usb 1-2: Product: EyeTV Stick
[ 3.307293] usb 1-2: Manufacturer: Geniatech
[ 3.307298] usb 1-2: SerialNumber: 160421
9165ba166cac5e8c9abda2012ea37cc3430c0b14 [media] usbtv: add sharpness control
[ 4.524977] dwc_otg: usb0: type: 2 speed: 0, config: 0, dma: 0, id: 0, phy: d0078000, ctrl: 0
[ 4.524991] dwc_otg_driver_probe host only, not probe usb_otg!!!
Hmmm. I was just trying something @fzinken suggested. After restarting, you will be back to square one so no surprise there. It’s possible you need to ‘manually’ start other drivers on which dvd_usb_cxusb depends as well. I don’t really know enough about how drivers are loaded to advise you but someone else may.
If it helps i run two of these adapters on a standalone x86_64 machine running debian stretch. I just ran lsmod on there and can see the following modules are loaded to support this device:
Hi.
After April update, the stick stills not working in Vero 4k, I don´t know if I can do somethink now, I hope you are less busy to have a look to this issue.
