My DVB-T2 stopped working completely after the last upgrade (second time in the last couple of years)
osmc@Vero4K:~/.hts$ dmesg | grep -i dvb
[ 3.783899] usb 1-2.3: Product: dvbt2
[ 3.783904] usb 1-2.3: Manufacturer: astrometadvbt2
[ 5.210777] usb 1-2.3: dvb_usb_v2: found a 'OSMC Engineering DVB-T2' in warm state
[ 5.295310] usb 1-2.3: dvb_usb_v2: will pass the complete MPEG2 transport stream to the software demuxer
[ 5.295343] dvbdev: DVB: registering new adapter (OSMC Engineering DVB-T2)
[ 5.296602] dvbdev: dvb_create_media_entity: media entity 'dvb-demux' registered.
[ 5.415972] usb 1-2.3: DVB: registering adapter 0 frontend 0 (Realtek RTL2832 (DVB-T))...
[ 5.415996] dvbdev: dvb_create_media_entity: media entity 'Realtek RTL2832 (DVB-T)' registered.
[ 5.416149] usb 1-2.3: DVB: registering adapter 0 frontend 1 (Panasonic MN88473)...
[ 5.416167] dvbdev: dvb_create_media_entity: media entity 'Panasonic MN88473' registered.
[ 5.568252] rc rc1: OSMC Engineering DVB-T2 as /devices/c9000000.dwc3/xhci-hcd.0.auto/usb1/1-2/1-2.3/rc/rc1
[ 5.568363] input: OSMC Engineering DVB-T2 as /devices/c9000000.dwc3/xhci-hcd.0.auto/usb1/1-2/1-2.3/rc/rc1/input9
[ 5.570475] rc rc1: lirc_dev: driver ir-lirc-codec (dvb_usb_rtl28xxu) registered at minor = 1
[ 5.570492] usb 1-2.3: dvb_usb_v2: schedule remote query interval to 200 msecs
[ 5.578547] usb 1-2.3: dvb_usb_v2: 'OSMC Engineering DVB-T2' successfully initialized and connected
[ 5.578687] usbcore: registered new interface driver dvb_usb_rtl28xxu
[ 20.866095] usb 1-2.3: DVB: adapter 0 frontend 0 frequency 0 out of range (174000000..862000000)
[ 21.418832] mn88473 1-0018: downloading firmware from file 'dvb-demod-mn88473-01.fw'
[ 22.063760] usb 1-2.3: DVB: adapter 0 frontend 1 frequency 0 out of range (42000000..1002000000)
[ 360.111507] usb 1-2.3: DVB: adapter 0 frontend 0 frequency 0 out of range (174000000..862000000)
[ 719.018674] usb 1-2.3: DVB: adapter 0 frontend 0 frequency 0 out of range (174000000..862000000)
Please post full logs and try a cold boot.
Hello Sam,
Thanks for the prompt reply.
I’ve done a cold boot, and I’ve also removed the DVB-T from USB hub and reconnected as this was a factor in the past when I had similar issues.
I also manually removed the adapter from the tvheadend but didn’t make any difference:
rm ~/.hts/tvheadend/input/linuxdvb/adapters/*
You can find full logs here:
https://paste.osmc.tv/penosupeza
The adapter is recognized properly but when I try to tune or scan it just fails to find anything.
Thinking of giving a second go to the osmc DVB-T2 USB tuner, if that will definitely work in future updates.
I’ll buy it.
Rocco
Same issue with your DVB-T2 Adapter.
This one comes up as Sony rather than panasonic but still fails to scan the muxes.
I’ll play with it more later, but it’s behaving just the same way.
dmesg | grep -i dvb
[ 3.743791] usb 1-2.3: Product: dvbt2
[ 3.743796] usb 1-2.3: Manufacturer: astrometadvbt2
[ 5.019699] usb 1-2.3: dvb_usb_v2: found a 'OSMC Engineering DVB-T2' in warm state
[ 5.107335] usb 1-2.3: dvb_usb_v2: will pass the complete MPEG2 transport stream to the software demuxer
[ 5.107369] dvbdev: DVB: registering new adapter (OSMC Engineering DVB-T2)
[ 5.108419] dvbdev: dvb_create_media_entity: media entity 'dvb-demux' registered.
[ 5.175154] i2c i2c-1: cxd2841er_attach(): attaching CXD2837ER DVB-C/T/T2 frontend
[ 5.175182] usb 1-2.3: DVB: registering adapter 0 frontend 0 (Realtek RTL2832 (DVB-T))...
[ 5.175202] dvbdev: dvb_create_media_entity: media entity 'Realtek RTL2832 (DVB-T)' registered.
[ 5.175370] usb 1-2.3: DVB: registering adapter 0 frontend 1 (Sony CXD2837ER DVB-T/T2/C demodulator)...
[ 5.175384] dvbdev: dvb_create_media_entity: media entity 'Sony CXD2837ER DVB-T/T2/C demodulator' registered.
[ 5.285774] rc rc1: OSMC Engineering DVB-T2 as /devices/c9000000.dwc3/xhci-hcd.0.auto/usb1/1-2/1-2.3/rc/rc1
[ 5.285888] input: OSMC Engineering DVB-T2 as /devices/c9000000.dwc3/xhci-hcd.0.auto/usb1/1-2/1-2.3/rc/rc1/input9
[ 5.287861] rc rc1: lirc_dev: driver ir-lirc-codec (dvb_usb_rtl28xxu) registered at minor = 1
[ 5.287882] usb 1-2.3: dvb_usb_v2: schedule remote query interval to 200 msecs
[ 5.296362] usb 1-2.3: dvb_usb_v2: 'OSMC Engineering DVB-T2' successfully initialized and connected
[ 5.296489] usbcore: registered new interface driver dvb_usb_rtl28xxu
[ 20.530350] usb 1-2.3: DVB: adapter 0 frontend 0 frequency 0 out of range (174000000..862000000)
[ 404.896040] usb 1-2.3: DVB: adapter 0 frontend 1 frequency 0 out of range (42000000..1002000000)
it was all working fine before the last update.
Any Idea.
Nevermind this was one of those (let me check if the cable is still plugged in) moment
Working Thanks.
just found out though that the tv tuner doesn’t like wam reboots, if I warm reboot it without unplugging it from powered usb hum it comes back without detecting the sony adapters and I can’t use it.
I need to reboot vero and remove the tuner from the hub in order to make it come back upon reboot, my previous tv tuner didn’t have this problem.
Can you try connected via USB directly without hub and verify if this is still the case?
Plugging it directly to Vero fixes the issue,
Getting mux scan failures again and I can’t tune on any of the existing channels that were working before.
I believe this has happened since the upgrade but not 100% sure, the timing seems to match but I can’t recall 100%
I have a proper OSMC DVB-T2 tuner, any idea?
Nothing has changed DVB side in this update, so can you please send us some logs?
Also worth checking the muxes haven’t changed in your local area
