it worked! all up and running! thanks so much…
Good to hear. Maybe @sam_nazarko could consider including these firmware files in the distro because this dongle is popular, at least in UK, and still the cheapest DVB-T2 stick on Amazon.
I plan to revamp DVB and WiFi firmwares for OSMC in the near future. I have made a note of this post on the list so these firmware files will be included when that happens.
Hi Sam,
I have recieved the vero 2 and i know its early days but i have this tuner in the UK and i have installed everything as mentioned but the dvb tunder still will not show up in the htstvheadend tv adapters section.
Here is the lsusb readout:
Bus 001 Device 005: ID 2252:1037
Bus 001 Device 006: ID 0572:c688 Conexant Systems (Rockwell), Inc.
Bus 001 Device 003: ID 1058:107c Western Digital Technologies, Inc.
Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port HUB
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
and here is the dmesg relevant part:
usb 2-1: USB disconnect, device number 2
[ 3782.353559] usb 1-1.2: new high-speed USB device number 6 using dwc_otg
[ 3782.455422] usb 1-1.2: string descriptor 0 malformed (err = -61), defaulting to 0x0409
[ 3782.461062] usb 1-1.2: New USB device found, idVendor=0572, idProduct=c688
[ 3782.461166] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
TVheadend is up to date and so is osmc with all of the relevant drivers present, not sure what else to do?
I will backport some DVB drivers for the next update
Thankyou is that the problem then? drivers?
No idea – as I haven’t seen a full log, but I would guess so
Hi Sam I know you probably very busy with other bits of vero 2 but was wondering if you had back ported those drivers in the recent update?
I have tried this with a fresh install and all the drivers installed (dvb-tuner-si2158-a20-01.fw & dvb-demod-si2168-02.fw) which I believe are pre-installed now in /lib/firmware but still to no avail.
lsusb
Bus 001 Device 004: ID 2252:1037
Bus 001 Device 005: ID 0572:c688 Conexant Systems (Rockwell), Inc.
lsmod
Module Size Used by
8021q 16495 0
cbc 2030 0
mali 160884 5
fuse 67246 3
am_net8218_osmc 31533 0
8189es 818464 0
cfg80211 182590 1 8189es
I am a little confused and am now wondering if I should just buy another tuner that is supported? any help would be appreciated
There are different versions of these files knocking around. The ones that work for me are:
-rwxr–r-- 1 root root 2728 Mar 31 2015 dvb-demod-si2168-b40-01.fw (aka dvb-demod-si2168-02.fw)
-rwxr–r-- 1 root root 3944 Mar 31 2015 dvb-tuner-si2158-a20-01.fw
Not sure why they have their exec bit set - probably unnecessary. The dates may just be when I last downloaded them.
