HI Sam
OK, here is the output from dmesg
osmc@osmc:~$ dmesg
[ 0.000000] Booting Linux on physical CPU 0xf00
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.18.13-1-osmc (root@vero) (gcc version 4.9.2 (Debi an 4.9.2-10) ) #1 SMP PREEMPT Sun May 17 18:50:26 UTC 2015
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instructio n cache
[ 0.000000] Machine model: Raspberry Pi 2 Model B
[ 0.000000] cma: Reserved 8 MiB at 0x2e800000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 192512
[ 0.000000] free_area_init_node: node 0, pgdat 809abd80, node_mem_map ae21300 0
[ 0.000000] Normal zone: 1504 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 192512 pages, LIFO batch:31
[ 0.000000] [bcm2709_smp_init_cpus] enter (8640->f3003010)
[ 0.000000] [bcm2709_smp_init_cpus] ncores=4
[ 0.000000] PERCPU: Embedded 10 pages/cpu @ae1e1000 s12096 r8192 d20672 u4096 0
[ 0.000000] pcpu-alloc: s12096 r8192 d20672 u40960 alloc=10*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pag es: 191008
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1280 bcm2708_fb.fbheight=720 bcm2709.boardrev=0x2a01041 bcm2709.serial=0x1f6c27f8 sms c95xx.macaddr=B8:27:EB:6C:27:F8 bcm2708_fb.fbswap=1 bcm2709.disk_led_gpio=47 bcm 2709.disk_led_active_low=0 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_ba se=0x3dc00000 vc_mem.mem_size=0x3f000000 root=/dev/mmcblk0p2 rootfstype=ext4 ro otwait quiet osmcdev=rbp2
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 744108K/770048K available (7249K kernel code, 401K rwdata , 1864K rodata, 388K init, 763K bss, 25940K reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xffe00000 (2048 kB)
vmalloc : 0xaf800000 - 0xff000000 (1272 MB)
lowmem : 0x80000000 - 0xaf000000 ( 752 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x80008000 - 0x808ee928 (9115 kB)
.init : 0x808ef000 - 0x80950000 ( 388 kB)
.data : 0x80950000 - 0x809b465c ( 402 kB)
.bss : 0x809b465c - 0x80a73594 ( 764 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:608
[ 0.000000] Architected cp15 timer(s) running at 19.20MHz (virt).
[ 0.000016] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 35791 39424256ns
[ 0.000038] Switching to timer-based delay loop, resolution 52ns
[ 0.000324] Console: colour dummy device 80x30
[ 0.000528] console [tty0] enabled
[ 0.000554] Calibrating delay loop (skipped), value calculated using timer fr equency… 38.40 BogoMIPS (lpj=192000)
[ 0.000585] pid_max: default: 32768 minimum: 301
[ 0.000967] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000989] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.002217] Initializing cgroup subsys memory
[ 0.002270] Initializing cgroup subsys devices
[ 0.002295] Initializing cgroup subsys freezer
[ 0.002317] Initializing cgroup subsys net_cls
[ 0.002352] Initializing cgroup subsys blkio
[ 0.002432] CPU: Testing write buffer coherency: ok
[ 0.002509] ftrace: allocating 18151 entries in 54 pages
[ 0.046769] CPU0: update cpu_capacity 1024
[ 0.046808] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 0.046827] [bcm2709_smp_prepare_cpus] enter
[ 0.046967] Setting up static identity map for 0x6aeea8 - 0x6aef00
[ 0.106715] [bcm2709_boot_secondary] cpu:1 started (0) 16
[ 0.107026] CPU1: Booted secondary processor
[ 0.107033] [bcm2709_secondary_init] enter cpu:1
[ 0.107089] CPU1: update cpu_capacity 1024
[ 0.107097] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ 0.126682] [bcm2709_boot_secondary] cpu:2 started (0) 18
[ 0.126941] CPU2: Booted secondary processor
[ 0.126948] [bcm2709_secondary_init] enter cpu:2
[ 0.126978] CPU2: update cpu_capacity 1024
[ 0.126986] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ 0.146714] [bcm2709_boot_secondary] cpu:3 started (0) 16
[ 0.146958] CPU3: Booted secondary processor
[ 0.146965] [bcm2709_secondary_init] enter cpu:3
[ 0.146994] CPU3: update cpu_capacity 1024
[ 0.147002] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ 0.147096] Brought up 4 CPUs
[ 0.147130] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.147141] CPU: All CPU(s) started in SVC mode.
[ 0.148147] devtmpfs: initialized
[ 0.173031] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.175060] pinctrl core: initialized pinctrl subsystem
[ 0.177991] NET: Registered protocol family 16
[ 0.183331] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.206525] cpuidle: using governor ladder
[ 0.236551] cpuidle: using governor menu
[ 0.236685] bcm2709.uart_clock = 3000000
[ 0.239475] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.239495] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.239528] mailbox: Broadcom VideoCore Mailbox driver
[ 0.239642] bcm2708_vcio: mailbox at f300b880
[ 0.239984] bcm_power: Broadcom power driver
[ 0.240002] bcm_power_open() -> 0
[ 0.240013] bcm_power_request(0, 8)
[ 0.740679] bcm_mailbox_read -> 00000080, 0
[ 0.740692] bcm_power_request -> 0
[ 0.740810] Serial: AMBA PL011 UART driver
[ 0.740940] dev:f1: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is a PL011 rev3
[ 0.809076] SCSI subsystem initialized
[ 0.809321] usbcore: registered new interface driver usbfs
[ 0.809426] usbcore: registered new interface driver hub
[ 0.809577] usbcore: registered new device driver usb
[ 0.811202] Switched to clocksource arch_sys_counter
[ 0.838718] FS-Cache: Loaded
[ 0.839032] CacheFiles: Loaded
[ 0.850625] NET: Registered protocol family 2
[ 0.852010] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.852153] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.852347] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.852458] TCP: reno registered
[ 0.852480] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.852544] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.853012] NET: Registered protocol family 1
[ 0.853443] RPC: Registered named UNIX socket transport module.
[ 0.853459] RPC: Registered udp transport module.
[ 0.853469] RPC: Registered tcp transport module.
[ 0.853480] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.853940] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counter s available
[ 0.854163] bcm2708_dma: DMA manager at f3007000
[ 0.854324] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000 000(1008 MiB)
[ 0.855938] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.856154] audit: initializing netlink subsys (disabled)
[ 0.856214] audit: type=2000 audit(0.829:1): initialized
[ 0.872121] VFS: Disk quotas dquot_6.5.2
[ 0.872501] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.875468] FS-Cache: Netfs ‘nfs’ registered for caching
[ 0.876478] NFS: Registering the id_resolver key type
[ 0.876600] Key type id_resolver registered
[ 0.876613] Key type id_legacy registered
[ 0.877641] msgmni has been set to 1469
[ 0.879646] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2 52)
[ 0.879839] io scheduler noop registered
[ 0.880148] io scheduler bfq registered (default)
[ 0.880158] BFQ I/O-scheduler version: v7r7
[ 0.882644] BCM2708FB: allocated DMA memory eec00000
[ 0.882687] BCM2708FB: allocated DMA channel 0 @ f3007000
[ 0.898419] Console: switching to colour frame buffer device 160x45
[ 0.909058] bcm2708-dmaengine bcm2708-dmaengine: Load BCM2835 DMA engine driv er
[ 0.909360] uart-pl011 dev:f1: no DMA platform data
[ 0.909834] vc-cma: Videocore CMA driver
[ 0.909849] vc-cma: vc_cma_base = 0x00000000
[ 0.909860] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 0.909871] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 0.921372] brd: module loaded
[ 0.927167] loop: module loaded
[ 0.927951] vchiq: vchiq_init_state: slot_zero = 0xaec80000, is_master = 0
[ 0.928772] Loading iSCSI transport class v2.0-870.
[ 0.929706] usbcore: registered new interface driver smsc95xx
[ 0.929781] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.130139] Core Release: 2.80a
[ 1.130163] Setting default values for core params
[ 1.130189] Finished setting default values for core params
[ 1.330580] Using Buffer DMA mode
[ 1.330597] Periodic Transfer Interrupt Enhancement - disabled
[ 1.330608] Multiprocessor Interrupt Enhancement - disabled
[ 1.330619] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.330636] Dedicated Tx FIFOs mode
[ 1.330988] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xaec 14000 dma = 0xeec14000 len=9024
[ 1.331028] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
[ 1.331052] dwc_otg: Microframe scheduler enabled
[ 1.331124] WARN::hcd_init_fiq:412: FIQ on core 1 at 0x804f8c30
[ 1.331144] WARN::hcd_init_fiq:413: FIQ ASM at 0x804f8fa0 length 36
[ 1.331164] WARN::hcd_init_fiq:438: MPHI regs_base at 0xaf80a000
[ 1.331219] dwc_otg bcm2708_usb: DWC OTG Controller
[ 1.331271] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[ 1.331319] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[ 1.331373] Init: Port Power? op_state=1
[ 1.331384] Init: Power Port (0)
[ 1.331713] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.331733] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 1.331749] usb usb1: Product: DWC OTG Controller
[ 1.331765] usb usb1: Manufacturer: Linux 3.18.13-1-osmc dwc_otg_hcd
[ 1.331781] usb usb1: SerialNumber: bcm2708_usb
[ 1.332769] hub 1-0:1.0: USB hub found
[ 1.332837] hub 1-0:1.0: 1 port detected
[ 1.333362] dwc_otg: FIQ enabled
[ 1.333375] dwc_otg: NAK holdoff enabled
[ 1.333385] dwc_otg: FIQ split-transaction FSM enabled
[ 1.333427] Module dwc_common_port init
[ 1.333787] usbcore: registered new interface driver usb-storage
[ 1.334063] mousedev: PS/2 mouse device common for all mice
[ 1.334951] bcm2835-cpufreq: min=600000 max=900000
[ 1.335274] sdhci: Secure Digital Host Controller Interface driver
[ 1.335287] sdhci: Copyright© Pierre Ossman
[ 1.335465] DMA channels allocated for the MMC driver
[ 1.371235] Load BCM2835 MMC driver
[ 1.371539] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.375412] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.377757] hidraw: raw HID events driver © Jiri Kosina
[ 1.378078] usbcore: registered new interface driver usbhid
[ 1.378091] usbhid: USB HID core driver
[ 1.378457] TCP: cubic registered
[ 1.378479] Initializing XFRM netlink socket
[ 1.378529] NET: Registered protocol family 17
[ 1.379783] Key type dns_resolver registered
[ 1.379958] Registering SWP/SWPB emulation handler
[ 1.383319] registered taskstats version 1
[ 1.385731] vc-sm: Videocore shared memory driver
[ 1.385752] [vc_sm_connected_init]: start
[ 1.386545] [vc_sm_connected_init]: end - returning 0
[ 1.387609] Waiting for root device /dev/mmcblk0p2…
[ 1.408642] mmc0: host does not support reading read-only switch, assuming wr ite-enable
[ 1.410772] mmc0: new high speed SDHC card at address b368
[ 1.411430] mmcblk0: mmc0:b368 USD 7.46 GiB
[ 1.412770] mmcblk0: p1 p2
[ 1.494233] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesyst em
[ 1.494255] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 1.531338] Indeed it is in host mode hprt0 = 00021501
[ 1.711309] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 1.711511] Indeed it is in host mode hprt0 = 00001101
[ 1.911551] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 1.911572] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.912592] hub 1-1:1.0: USB hub found
[ 1.912724] hub 1-1:1.0: 5 ports detected
[ 2.191308] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 2.291520] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 2.291541] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber =0
[ 2.294415] smsc95xx v1.0.4
[ 2.355093] smsc95xx 1-1.1:1.0 eth0: register ‘smsc95xx’ at usb-bcm2708_usb-1 .1, smsc95xx USB 2.0 Ethernet, b8:27:eb:6c:27:f8
[ 2.601301] usb 1-1.3: new high-speed USB device number 4 using dwc_otg
[ 2.702045] usb 1-1.3: New USB device found, idVendor=0572, idProduct=c688
[ 2.702067] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber =3
[ 2.702082] usb 1-1.3: Product: USB Stick
[ 2.702097] usb 1-1.3: Manufacturer: Max
[ 2.702112] usb 1-1.3: SerialNumber: 080116
[ 6.657418] EXT4-fs (mmcblk0p2): recovery complete
[ 7.150646] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. O pts: (null)
[ 7.150720] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 7.159828] devtmpfs: mounted
[ 7.160489] Freeing unused kernel memory: 388K (808ef000 - 80950000)
[ 8.683379] random: systemd urandom read with 82 bits of entropy available
[ 8.740780] NET: Registered protocol family 10
[ 9.164492] systemd[1]: Cannot add dependency job for unit display-manager.se rvice, ignoring: Unit display-manager.service failed to load: No such file or di rectory.
[ 9.164868] systemd[1]: Found ordering cycle on basic.target/start
[ 9.164897] systemd[1]: Found dependency on sysinit.target/start
[ 9.164926] systemd[1]: Found dependency on kbd.service/start
[ 9.164954] systemd[1]: Found dependency on remote-fs.target/start
[ 9.164979] systemd[1]: Found dependency on remote-fs-pre.target/start
[ 9.165003] systemd[1]: Found dependency on connman.service/start
[ 9.165027] systemd[1]: Found dependency on basic.target/start
[ 9.165055] systemd[1]: Breaking ordering cycle by deleting job kbd.service/s tart
[ 9.165085] systemd[1]: Job kbd.service/start deleted to break ordering cycle starting with basic.target/start
[ 9.263320] fuse init (API version 7.23)
[ 9.341142] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 9.686945] systemd-udevd[123]: starting version 215
[ 10.297629] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 11.182616] Installing knfsd (copyright © 1996 okir@monad.swb.de).
[ 11.469731] random: nonblocking pool is initialized
[ 12.121319] systemd-journald[104]: Received request to flush runtime journal from PID 1
[ 12.923065] smsc95xx 1-1.1:1.0 eth0: hardware isn’t capable of remote wakeup
[ 12.923283] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 14.437766] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 14.439622] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x45E 1
[ 14.576128] 8021q: 802.1Q VLAN Support v1.8
[ 19.763279] Console: switching to colour dummy device 80x30
osmc@osmc:~$
