Hello,
Do you if, by any luck, there are some tuners adapted to be plugged on RPi’s GPIO?
I would like to create my own TV-box hence, I can’t use USB because I want to integrate the tuner inside the box and let the USB ports on the box edge.
I am under no illusion that’s not the aim of GPIO, but I’m trying anyway
Thank you in advance!
DarkPatate
