Hi;
I have a DVB usb based in RTL2832u Chipset and i would like use it in my Raspberry Pi, anybody can help me?
thanks in advance
Hi;
thanks in advance
Have you tried setting it up with TVHeadend so far?
Yes, my dmesg not recognize it,
[ 2.670238] usb 1-1.5: new high-speed USB device number 5 using dwc_otg
[ 2.781241] usb 1-1.5: New USB device found, idVendor=1b80, idProduct=d398
[ 2.781282] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.781303] usb 1-1.5: Product: usbtv
[ 2.781319] usb 1-1.5: Manufacturer: realtek
[ 2.845470] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[ 3.020228] usb 1-1.3: new high-speed USB device number 6 using dwc_otg
[ 3.095390] fuse init (API version 7.23)
[ 3.121428] usb 1-1.3: New USB device found, idVendor=18a5, idProduct=0400
[ 3.121501] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.121520] usb 1-1.3: Product: USB 3.0 Desktop HD
[ 3.121536] usb 1-1.3: Manufacturer: Verbatim
[ 3.121553] usb 1-1.3: SerialNumber: 306247043850
[ 3.135167] usb-storage 1-1.3:1.0: USB Mass Storage device detected
Suspect we need to add firmware for that. I’ll try get it in for the next release.
thanks for all
I would like to have the option to switch between using the DVBT dongle both as a Tv receiver and as a RTL-SDR device, I think that requires 2 different drivers!?
Here is driver for Realtek.
Or
Compiling for Raspbmc
BBerski
Looked at this
rtl28xx module is enabled in our kernel, so perhaps a new vendor ID needs to be patched in.
Perfect @sam_nazarko
Can you patch with these ID
#define USB_PID_KWORLD2_TURBOX_USB2_DVB_T 0xd398
and recompile .
Can I test if it works
BBerski
Which file does this need to be added to? The driver files seem to be:
./drivers/media/usb/em28xx/em28xx-reg.h
./drivers/media/usb/em28xx/em28xx-cards.c
./drivers/media/usb/em28xx/em28xx-v4l.h
./drivers/media/usb/em28xx/em28xx-i2c.c
./drivers/media/usb/em28xx/em28xx-core.c
./drivers/media/usb/em28xx/em28xx-audio.c
./drivers/media/usb/em28xx/Makefile
./drivers/media/usb/em28xx/em28xx-camera.c
./drivers/media/usb/em28xx/em28xx.h
./drivers/media/usb/em28xx/em28xx-vbi.c
./drivers/media/usb/em28xx/em28xx-input.c
./drivers/media/usb/em28xx/Kconfig
./drivers/media/usb/em28xx/em28xx-dvb.c
./drivers/media/usb/em28xx/em28xx-video.c
./drivers/media/usb/dvb-usb-v2/rtl28xxu.h
./drivers/media/usb/dvb-usb-v2/rtl28xxu.c
linux/drivers/media/dvb-core/dvb-usb-ids.h
@388
linux/drivers/media/usb/dvb-usb-v2/rtl28xxu.c
@1652
{ DVB_USB_DEVICE(USB_VID_KWORLD_2, 0xd398,
&rtl2832u_props, “Realtek 2832U USB DVB-T Stick RC”, NULL) },
I will merge this for Alpha 4 and would appreciate it if you could update this thread when it is released and let me know if it worked.
BBerski
This will be in Alpha 4 which should come soon
osmc@osmc:~$ lsmod |grep rtl
dvb_usb_rtl28xxu 20165 14
rtl2830 10674 1 dvb_usb_rtl28xxu
rtl2832 11555 3 dvb_usb_rtl28xxu
i2c_mux 2459 1 rtl2832
dvb_usb_v2 16993 1 dvb_usb_rtl28xxu
dvb_core 106775 3 rtl2830,rtl2832,dvb_usb_v2
rc_core 25875 15 ir_sharp_decoder,ir_xmp_decoder,lirc_dev,ir_lirc_codec,dvb_usb_rtl28xxu,ir_rc5_decoder,ir_nec_decoder,ir_sony_decoder,ir_mce_kbd_decoder,ir_jvc_decoder,dvb_usb_v2,ir_rc6_decoder,ir_sanyo_decoder
BBerski
Great,
I can use my DBV usb stick now.
Thanks ,
The Alpha 4 release is imminent and will have this included.
I have a QNAP DVB USB receiver based on Realtek RTL2832u chipset.
This is my dmesg at connect:
[175901.335815] usb 1-1.3.4: new high-speed USB device number 7 using dwc_otg
[175901.454890] usb 1-1.3.4: New USB device found, idVendor=1b80, idProduct=d3a4
[175901.454935] usb 1-1.3.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[175901.454953] usb 1-1.3.4: Product: Rtl2832UDVB
[175901.454969] usb 1-1.3.4: Manufacturer: Realtek
No new DVB events in dmesg for this receiver.
I have another receiver connected (AVerMedia HD Volar (A867)) that works and store dmesg DVB events:
[ 8.954584] usb 1-1.3.1: dvb_usb_af9035: prechip_version=00 chip_version=03 chip_type=3802
[ 8.955057] usb 1-1.3.1: dvb_usb_v2: found a ‘AVerMedia HD Volar (A867)’ in cold state
[ 8.977301] usb 1-1.3.1: dvb_usb_v2: downloading firmware from file ‘dvb-usb-af9035-02.fw’
[ 9.293022] usb 1-1.3.1: dvb_usb_af9035: firmware version=12.13.15.0
[ 9.293101] usb 1-1.3.1: dvb_usb_v2: found a ‘AVerMedia HD Volar (A867)’ in warm state
[ 9.313051] usb 1-1.3.1: dvb_usb_v2: will pass the complete MPEG2 transport stream to the software demuxer
[ 9.831326] usb 1-1.3.1: dvb_usb_v2: schedule remote query interval to 500 msecs
[ 9.831355] usb 1-1.3.1: dvb_usb_v2: ‘AVerMedia HD Volar (A867)’ successfully initialized and connected
[ 9.835519] usbcore: registered new interface driver dvb_usb_af9035
May be the idVendor=1b80, idProduct=d3a4 of my QNAP-Realtek not yet patched in alpha4 release ?
Can you help me ?
Thank for all
Paolo
Hi everybody, same problem here.
I’ve bought a Hamlet XDVBT900BK, which has the same chipset, idVendor and idProduct as @sampeiilpescatore’s receiver. I’ve noticed that idProduct=d3a4 has already been added in module sources from LinuxTV.org, so I tried to build the module by myself, but I get this error during building process on RPI 1:
In file included from ./arch/arm/include/asm/page.h:163:0,
from ./arch/arm/include/asm/thread_info.h:17,
from include/linux/thread_info.h:54,
from include/asm-generic/preempt.h:4,
from arch/arm/include/generated/asm/preempt.h:1,
from include/linux/preempt.h:18,
from include/linux/spinlock.h:50,
from include/linux/seqlock.h:35,
from include/linux/time.h:5,
from include/linux/input.h:11,
from /home/osmc/LinuxDriver/Linux/Linux/v4l/compat.h:9,
./arch/arm/include/asm/memory.h:24:25: fatal error: mach/memory.h: No such file or directory
#include <mach/memory.h
and a similar error, related to missing file mach/barriers.h, if I try to build on RPI 2.
Any suggestion/fix for this problem ? Alternatively, can anybody indicate a dvb-t usb tuner proven to work out-of-the-box with OSMC ?
Thank you very much
Giuseppe
Hello is this working as yet?
I have a RPI2 with the latest image and RTL2832u based dongle talking to OSMC via TVHeadend. TV Headend sees the dongle but it does not function…
Many thanks.
