I am happily running OSMC (version December 2018) on my Raspberry Pi 3. Today I have connected a powered DVD player and it doesn’t add any “Play Disc” menu on the home page. I can play the disc browing in “Video” then “Files”, but it is very uncomfortable.
I am using standard OSMC skin. Do I have to change something in settings in order to have a “Play Disc” menu entry?
I think you may get the ‘Play Disc’ appearing when the DVD is loaded using the Confluence skin.
With the default OSMC skin you get the DVD name appearing under Videos/files and can play using the context menu, as you observed.
That thread referrred to is a rather old one - things have moved on.
Derek
As far as I know you can select the disc press the 3 lines button on the vero remote and select play from the menu. You don’t have to navigate through the dvd file structure and select the correct .vob file if that’s inconvenient
The “Play Disc” appears (and it is working) in my OSMC skin! The problem is that it is listed around the bottom of the menu and I haven’t realize I had to scroll down!!
